Car Care Nut Warning
#31
This is not true on any level lol
If an LS460 is a "money pit" you have no business driving a high end car. Its the most reliable high end car you can buy. Not perfect, and has needs but those needs are way easier to deal with than what kinds of needs you could have from a comparable S Class or 7 Series etc.
The 460 is a better car than the 430, but many of the reasons why it is a better car make it costlier to maintain.
#32
#33
How can you be so angry at an automobile manufacturer? Did you get screwed on a LS purchase or what, you've been asking year and mileage on these cars on several problem threads and posts.
Are you gearing up for some type of class action? if so pencil me in if the paperwork is accepted.
#34
Look at all of the people here who have these cars and repair them here and there and take care of them and their experience is just fine. The worst thing you can do is not maintain a 460, same as an S Class or 7 Series, an LS430 you can leave half broken and it will be fine. Amd says that in his video too.
It’s a car like a German car that delivers performance first, and ease and cost of repair second. It’s still more reliable than a German car though. Do you want to talk about what type of issues a 2011 S550 or 740i could potentially have? Dramatically more than this. The M278 motors in the S550 can develop an oil back pressure into the wiring harness that totals the car lol. Bore scoring that ruins the engine. It goes on
#35
But it delivers much better performance than the previous LSs, that’s the point. Everything he says is true, but the trade off is what caliber of car do you want? If you want something sophisticated like a German flagship sedan like I do, then it is what it is, this is potentially what you are going to deal with. I’ve had the 400, 430 and two 460s. I would pay for the upkeep on the 460 every day.
#36
Valley plate leak is not fine it's a huge repair even for the most experienced DIY'er.
That's not what he says at all, he flat out warned people not to own the 460 unless they are willing to deal with the design flaws over and over again.
]That's hardly the point, it is much more costly to own vs. the previous generation. And let's be clear, these are engineering failures not typical or Lexus.
Point is every car like this has common issues as they get old. Remember that car is 13 years old. The LS460 is dramatically less expensive to maintain than a comparable German car, and it is comparable to those German cars where the previous generations really weren’t.
None of this makes the LS460 any less of a pain to own long term.
Striker223 (03-20-24)
#37
No, but plenty of other people here have including people participating in this thread and agreeing with me. LS460 doesn’t have a UZ engine. How many 1UR engines have you worked on?
I have put nearly 300k miles on 1UZ and 3UZ engines I owned.
#39
I've only ever done minor things on the LS460 it is not a car have expertise in. But I've worked on just about every Toyota/Lexus engine made at some point.
#40
All of this is well within my scope of understanding thank you. It seems all the ways in which the LS460 is superior to the previous generations is over your head, as are the realities of living with the other comparable cars. I don't see it as a problem because I know what the maintenance requirements of this caliber car are.
If by your admission you are not familiar with the LS460, why are you in here arguing with those of us who are?! I’ll listen to the folks who have had and know these cars thanks. Which includes me.
Let’s put it this way, I have an S Class now. Why would I sit here and argue with you about why the LS460 is a smarter car to own long term than the car I have if I didn’t truly believe that to be true?
A single mechanics visit can total any car that is only with $5,000 lol. If you have kept up with the car and it’s well cared for no mechanic visit is going to total it. A timing belt on my ES300 would total it, does that mean it isn’t a good car? It’s just old and worth very little.
The following 2 users liked this post by SW17LS:
Marc780 (03-28-24),
#41
Lets explore what we are really talking about here, these are the common issues with the LS460:
1. Valley plate leak: $1,500
2. Control arms: $3,000 with OEM parts, $1,500 with aftermarket parts
3. Brake actuator: $2,500 with OEM parts, $1,500 with aftermarket parts. This rarely actually fails
Thats really it. There are other things here and there that can come up, common Lexus/Toyota issues like door lock actuators and window motors which were also an issue with all models. Air suspension if equipped is an issue with all models.
For comparison, one set of brakes for my S560 at an independent shop with aftermarket pads and OEM rotors was $2,149.16 at 30,000 miles. Yes it needed new brakes and rotors front and rear at 30k miles...and it will again at 60k miles....and 90k miles. My LS460s needed front brakes around 40k miles at a cost of $453 for pads and rotors. Rears were done about 50k miles at a cost of $274...
It costs about 3 times to do anything to the Mercedes as it cost to do to the LS460...and they do also need control arm bushings around 70-80k miles and the ones with the M278 engine have a LOT of engine related issues that the M176 I have seems not to have, but it still has turbos and a lot of potential costs the LS460 doesn't have. There are also coolant leaks that are common with the Mercedes as well has head gaskets and rear main seal leaks, you wont get ANY of that worked on by an independent Mercedes tech for less than $3k.
So even with those common issues, the LS460 is much cheaper to maintain while delivering 90% of the driving enjoyment and luxury.
The following 4 users liked this post by SW17LS:
#42
The level of capitulation to bad design in this comment of yours is ridiculously embarrassing and unforgiving.
The rubber suspension disintegrates easily: oh it’s like a German car with better performance than before
The sealant degrades easily around the valley plate: oh it’s like a German car with better performance than before
It burns oil: oh it’s like a German car with better performance than before
EVERY SINGLE LEXUS LS HAS BEEN AN INCREASE IN PERFORMANCE, REFINEMENT AND COMPLICATION COMPARED TO THE ONE BEFORE IT. And reliability has CONSISTENTLY only improved with every generation despite it already having excellent reliability each time. As I said before, there is no excuse for these issues period. All of these issues have fixes and lexus should have fixed them. To say “oh it’s like a German car with more performance and more “maintenance” is a capitulated copout!! My respect is reserved for solutions, not excuses!
Ive owned both. I know what is cheaper and has less issues, at the top end Lexus just isn't competitive. If you want midrange cars then Lexus is great and they will give you less issues due to being a rebadged Camry and Highlander
#43
exactly and there is NO EXCUSE for the 460 to be as bad as it is. NONE!!! Anyone who uses the 7 series and the s class as a baseline has already set the bar very low regarding reliability expectations for the ls460. Lexus needs to stand behind these defects. It is not befitting of the stellar reputation the LS has garnered since inception.
I could hand people keys to each of them and ask them what they thought of each for comfort, quietness, ride, handling, etc etc etc
The 430 lost every single time in every aspect.
Since I had all 3 I have also worked on all 3 and I'll tell you right now the 430 is way more simple and a lot of repairs take over book time and fight. The 460 is about even with predictions.....I have yet to ever take as long as book on my German cars. Jobs that claim 12 hours I've gotten done in 4 and they have never fought me
#45
This thread is about technical problems. Maybe what AMD talked about went over your head or you don't see it as a serious problem. It is, and increases cost of ownership dramatically to the point where as he points out a single mechanic visit can total the car.
I've worked on nearly ALL of them. The only ones I've not seen is the M120 and the pre-2000 era BMW V8s....and again let me tell you that on the high end it's a different game. The UZ is fine until it has a major pain in the *** issue like cam seals or upper pan that are age related and everything around it will fight you on the way out. That takes a huge amount of time, more time than it take me to drop a 4.2 Audi V8 out of the car and replace the rear mounted chains.
