Very rarely, my LS shudders at highway speeds; goes away when slowing down to 20mph
10th Gear
My LS460L 2014 has 150k miles, and very rarely (like once a month), when im cruising on the highway, I get this very sudden very random shudder/ vibration. It’s not too pronounced and it just feels like the car suddenly became rougher, like it stopped being a luxury car and became a truck.
Goes away when I slow down and doesn’t come back for a while, probably 2 weeks or a month. Very random.
What could it be?
What could it be?
Is this shuddering from the engine or suspension? If engine, do you have any store codes? Suspension wise the upper control arms are known to go bad at some point. I'm currently dealing with a similar suspension issue. I have some crunchy sounds coming from the drivers front. I think it's the lower ball joint, or the lower, forward control arm bushing. I've got to get it up on a lift this weekend and check it out. At 73-78 mph I get a slight shimmy/vibration from that tire. Like a dynamic unbalance, but the tire's have been balanced multiple times so I think a bushing or ball joint is worn. Once I get to 80mph the vibration goes away. And anything under 70 mph I don't feel or notice it. The front suspension of the LS460's have 4 ball joints so if one of them is worn it's allowing your wheel to move in not-nice ways.
Next time it happens take your foot off the gas pedal, if it's still there shift into neutral and see what happens.
10th Gear
10th Gear
If it only happens once a month it could even be the section of road you happen to be on and the condition of your tires...you said it stops when you slow down. You need to drive it and have a plan to try a few different things when it's happens, make a few notes if you have to.
Striker223 (03-26-24)
In addition to the above good advice, is your car AWD. If it is, have you had the Transfer case oil changed? These cars use a specific oil that has no other source than Toyota. You cannot use an alternate and if you don't use the $200 a quart Toyota stuff you will get a shudder. Good part is it only takes .75 of a quart to change it.
Marc780 (03-29-24)
Spartan117
04-16-22 09:41 AM
I8ABMR
03-17-11 07:48 PM
