2013+ led headlights
Do you mean you want to replace the OEM bulb with LED's or that you want to replace the entire headlight assembly with the LED Jewel headlights from the LS600h? There are many various 12V halogen to LED conversions... but idk about HID to LED?... as far as I know LED's and HID's throw roughly the same amount of light. There was a video Torque Test Channel on youtube compared HID's to other cheap LED's and the OEM HID bulb was the best.
I believe those LED headlights coming with "Adaptive Front Lighting System" only. It is connected to the steering and the headlight has two actuators that point light beam not just up and down, but also in the direction you are turning. All that music has a computer gizmo that controls it. Not sure how HID setup works, they might not be compatible. With that said, there is an adapter harness that allows to install headlights from LS600 on LS460, so there's probably something for the LED unit as well.
I'm not recommending anything but looks like it's possible, this guy is working on an ISF.
https://www.youtube.com/watch?v=YXD7BAjaMOU
OK, I think I figured this out. The full LED style headlights for the LS460 were an optional extra. They came standard on all LS600h's. So if you have the headlight assembly that has 3 separate "bulbs" and looks like this, then you have the LED option. Seems like the LED versions get auto high beam functionality too? If you have the standard headlight assembly then you have HID's for the low and high beam and your beams will swivel automatically.
hhss (04-03-24)
The headlight assemblies be expensive, why replace it if your existing lights/assemblies are already good...? So probably not. Especially for the MY 2013+, I like my car how it is :P. I'd imagine it's a plug and play replacement, I doubt Lexus had two different wiring harnesses.
hhss (04-03-24)
dan25man (04-04-24)
rominl
12-02-07 06:21 PM
