Is it possible to remove the radiator fan assembly without removing the radiator?
Almost a year ago I replaced the radiator. I think I pulled the radiator out with fans still attached. Now the fan(s) are bad. It appears one of the fans came off the motor, or maybe the bearing went out. The other seems loose. I'd like to avoid removing the radiator if possible. That one detached fan vibrates the entire car something fierce.
