AWD to RWD Conversion (Theoretical)
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
Not trying to do this actively yet. My 300,000+ mi engine and transmission are worn (everything still works A-OK) BUT I had a long drive the other day. I was thinking IF I had to replace it with a used Motor+Trans combo, could I do a RWD conversion...
As I understand the center differential is a torsion unit and it is completely mechanically. The front and read differentials are also open diffs and mechanical. If you removed the FWD drive shaft, center differential, installed RWD transmission mount, and removed and replaced the AFT AWD driveshaft with the AFT RWD driveshaft, then the car would be none the wiser? The front differential and CV axles would just keep rotating, but not be driven anymore?
Is there anything in the Engine ECU, or TCU that would throw codes or faults? Does the car even know it's an AWD? I mean the transmissions are the same between the AWD, and RWD... Maybe the RWD mount might not fix on the AWD trans housing?
Thoughts?
Thoughts?
The following 2 users liked this post by JohnnyC407:
davidcvigi (04-22-24),
DavidinCT (04-19-24)
