Auxiliary Audio Input for LS600hL With Mark Levinson Sound
10th Gear
Hi everyone,
I'm new to the forum and I'm curious about how to play an iPod in my 2008 LS600h. I saw online that I can use an auxiliary jack that plugs into the iPod's earbud port(?), but it doesn't show if the vehicle requires the other end of the jack to be a USB or another male auxiliary jack? Does anyone know or recommend something I can use? Thanks very much!
Look in the center console for audio inputs.
Hi Suzie. I have the same model. Under the front centre arm rest you should find a 3.5mm stereo jack socket. The DISC/AUX button on the stereo toggles between the CD/DVD and the aux socket (as long as it detects that something is plugged in). You can get a cable from Amazon with a lightning plug on one end, and a USB and 3.5mm jack on the other. That, plus a car cigarette lighter / USB socket, will allow you to plug your phone in for power and audio.
SuzieCue (05-05-24)
10th Gear
Evansj, Thank you so much. I really appreciate the help. Now I know exactly what to buy. By the way, how do you like your 600hL? Have you ever had any issues with the car?
JohnnyC407 (05-06-24)
I’ve only had it for 6 months. I deliberately bought it at the cheaper end of the market knowing I would be putting some money into it. I spent nearly £2k at the dealer giving it a major service and a replacement sunroof. I have since had the rear exhaust boxes replaced with aftermarket parts and I’m not a massive fan (too noisy) so I might end up replacing them again with stock. However, the next job will probably be front suspension - there’s a knocking noise from the right wheel.
It’s a great car to drive, and fortunately I don’t commute to work so I can afford to refuel it. The reclining rear seat is really cool too.
Rosson3ri
02-02-16 11:49 PM
mafpolo
01-23-09 10:47 PM
