Are engine covers needed?
Is there any purpose to the engine covers other than aesthetic’s? They’re a pain to deal with when I when I just want to do a visual inspection, I’d like to just keep them off. The only one I notice that may be functional is the one that is connected to the air intake in the front.
Fastnlight (05-17-24)
I did a post about this too. Same reasons as you. The general opinion was that they should (probably) be left in place since that's how Lexus designed it to be.
I did leave them alone, for a while. But the last time I changed my air filters and had to take em off I just didn't put most of them back on. With one exception: the plastic cover that goes over the battery. That bit is what re-routes rain water and keeps the battery terminals from possibly shorting out.
The following 2 users liked this post by Marc780:
dlbuckls10 (05-17-24),
I ditched the centre engine cover because it doesn't have anything to do with airflow except to impede it and the foam padding on the under side of it holds in heat and maybe cuts down on engine noise slightly.
I left the side covers and the strips that attach to the fenders because without them you would risk getting water on and around the many components they cover when at a car wash. The front covers are the only ones that have a purpose imo, directing air up from the grille into the air intake ducts.
When I get around to doing the valley plate seal I will have a close look at the foam pieces in that area because all they can do in that area is reduce some noise and hold in heat baking plastic parts a little quicker.
The following 3 users liked this post by Gerf:
I hate engine covers. I like to see the engine. I've left mine on, but I don't see any harm in removing them.
The following 2 users liked this post by Nospinzone:
Fastnlight (05-18-24),
Marc780 (05-19-24)
If for no other reason, a clean engine helps you spot leaks and it is just nicer to maintain in general. I can't imagine letting my LS engine get dirty now, I love the car the most of every one I ever owned. I worked for a long time to own a car of this quality and I want her to look it! Besides the obvious thing, it is ever so much easier to keep a clean engine clean, than it is cleaning it after 10 years of accumulated crud (Sometimes I'll even spritz connections w silicone spray, and do other small things like clean/anti-seize on the battery bolts etc. because why not?)
I'ma have to have someone explain how foam and plastic covers "hold in heat and bake plastic parts"? Y'all know the coolant/oil temp gets to ~200F ain't no way some foam and plastic hold in more heat from the aluminum block with constant explosions happening inches away from all the injectors/sensors. Thermal convection is a thing, but it's not going to make a difference to engine thermals with the plastics on or not. Making it quiet is part of the Lexus/Luxury car refinement. I mean, to each their own, when I was regularly working on my 460 I had the covers off until I finished all the work, but they live on the car now.
^Correct. Folks are concerned about a piece of plastic holding in heat but have no concern over the hood that's a few inches away when closed. Basically it boils down to the owner if the covers stay or go. But the purpose of the covers is to reduce engine noise. Quiet and smooth ride is what makes these cars so great.
The following 2 users liked this post by THEunderPSI:
Fastnlight (05-21-24),
Marc780 (05-27-24)
Looks nice when you can see the mechanical components, that is what we pop the hood for anyway.
Lexus missed the boat on showing off the mechanical bits, as with a bit of design work, it could have looked very professional uncovered.
I don't like taking a redundant hood off anyway. The OEM's could have done the same sound deadening with the technical acoustic parts directly attached to the hood structure.
Unless you are an idiot you can just spray the whole engine bay down with foam etc, I don't have a picture of the LS460s bay foamed down but I spray it every other wash to make sure it remains clean.
I've done it to all my cars so that I know instantly if there are leaks and so that there is no dust, pull the plastic covers off and just stay about 1 foot away from most stuff. Don't go after the fuse boxes or anything like that and it's fine
Best way to avoid heat soak is to just open the hood when you get home, I also have both my Audis sets to after run their main fans and electric cooling pumps so they don't sit hot when I'm out and about.
Ok, foam will hold in heat by its insulating properties and I didn't say that plastic covers will. Also I was speaking about the foam in and around the valley plate area and used the phrase (a little quicker) I guess I should've been clearer because I just assumed anyone that read this would know I was speaking about after the car was turned off.
Not many here are mind readers
