2007 Lexus ls 460 L rear passenger air suspension issue
8th Gear
Hello, I have a question. I installed the new arnott air industry strut for the original ones were going bad and I have seen good reviews about the company. After installing everything, they both aired up well as the compressor is working but when the car is off and left for a while, I notice that the rear passenger side is bottomed out like if there is no air. Turned on the car again to see what will happen for I thought the line disconnected but it aired up just well and took it for a drive and it was holding it’s own weight. Did anyone experience this issue and if so, what they did to fix the issue or does anyone know what the issue is and how to fix it. Replaced both driver rear and passenger rear and the driver rear is holding up well even when the car is off. ( the rear passenger only bottoms out when the car is off)
Fastnlight (06-12-24)
Had the same issue with the front driver's side air shock and having both front shocks replaced. Took it back to the shop and it was a leaking front driver's side airline that was replaced.
truongsean
10-25-22 10:22 AM
