LED height adjustment
I found instructions to adjust the height of the bulbs with the screws. However, I have the LED ones that turn with the wheel and it looks different. I see no screws to adjust. Is it normal for them to seem a little low?
Against a wall, they’re straight and look good. But driving, it just seems like they could be a tad higher. How do you raise them a bit on the LED version?
lili43 (07-10-24)
Just move it till you get close to the height you want.
So if I understand… the plastic one highlighted in the picture, you just insert and turn screwdriver. The other one is a metal gear dial and slowly (and difficult) turn it gear teeth by gear teeth?
There are 2 adjustment screws. The outside one is a white plastic cap, this adjusts horizontally. There is an inside one about 6 inches away from the white cap and 4 inches lower. The inside screw adjusts vertically. Both can be found on the outer half of the headlight assembly under the fender panel so you have to remove 2 black cowls to reach them.
It seems to me that the horizontal adjustment took more turns to move than the vertical.
