Can't fit new air strut suspension no clearance
Old 07-19-24, 08:51 AM
handogg
handogg's Avatar
Is it really? Should I replace brake hose ?
Old 07-19-24, 08:55 AM
handogg
handogg's Avatar
I have another question I've found it challenging to find an answer for? How much force does it take for a new Lexus OEM Air strut to compress? With my entire body weight of 175 pounds on top of the new air strut, it wouldn't budge? Is it supposed to ? Thanks.
Old 07-19-24, 09:09 AM
Anfanger
Anfanger's Avatar
The strut looks extended, is it pressurized?
Old 07-19-24, 09:51 AM
Received 1,204 Likes on 893 Posts
Depressurize it or undo the lower arm....or use a large pry bar or something lol!
LS460Crown (07-19-24)
Old 07-19-24, 10:09 AM
Gerf
Gerf's Avatar
it is a used original part.
If there isn't a cap or something on the air inlet then the unit is probably pooched.
Old 07-19-24, 10:35 AM
handogg
handogg's Avatar
so it is supposed to move a bit more freely?
Old 07-19-24, 02:51 PM
miket000
miket000's Avatar
When I replaced my air struts I used a ratchet strap to compress them. By using a ratchet strap on the old one hardly any suspension components need to be removed. Once the old strut is out take the strap off. Then compress the new strut with the strap and install it. This is on an LS600 the air strut is slightly different. I assume the 460 can be done in a similar fashion.
Old 07-19-24, 03:09 PM
handogg
handogg's Avatar
Thank you I sincerely appreciate your reply.. it looks like the top ring snapped off due to the strap. I only mention because the right side came like that w/ the top ring snapped off..
Old 07-19-24, 11:17 PM
miket000
miket000's Avatar
If your new strut came with the ring snapped off I'd try to get a replacement.
In my pic the one with the ring snapped off is the one I was removing. It was also leaking all over the floor. If the ring is off the strut it's toast, at least on a 600. They are not meant to come off. The rubber on mine was deteriorated likely from the strut oil leaking down it. I installed my new ones with the strap attached the same way. The ring did flex a bit but no rips. You can also use 2 or 3 straps to compress it more evenly. I may have used 2 straps to install them. I don't remember for sure.
Old 07-19-24, 11:29 PM
miket000
miket000's Avatar
Also one of my old struts would not compress, well maybe an inch or so ( straps had trouble compressing it too). I think what happens is the fluid leaks internally into a section of the strut where it doesn't belong, thus preventing the strut from compressing. The ride from my locked strut was crazy hard. That single strut felt like it was hitting the bump stops over minor road imperfections.
Old 07-20-24, 01:47 PM
handogg
handogg's Avatar
so it sounds like I was sold a bad used part and I'm likely out the $$$$ I spent on it
2low
05-30-24 07:38 PM
ontheroad
04-18-23 07:06 AM
ptomasek
RX - 3rd Gen (2010-2015)
07-17-22 04:58 PM
jdanielca
07-19-19 07:06 AM
Hannaabe
06-25-16 09:35 AM
Quick Reply: Can't fit new air strut suspension no clearance
