Can't fit new air strut suspension no clearance
#31
Don't adjust the ride height sensors. You may open a can of worms. If removed , ust verify you connected them correctly.
#33
I've swapped struts out on 2 of our LS's without messing with them. I've posted my ride height numbers a few times to help other members that have tried adjusting them. If you (op) don't have techstrream I wouldn't mess with them.
Anfanger (09-05-24)
#35
thank you so much for the replies. the next day after starting the car several times it raised up.on its own the car isnt level i likely have 3 more struts to change out however car is driveable and im so happy for that on to p2241 oxygen sensor !
#36
Techstream isn't used to adjust the ride height sensors. They are mechanical as are the measurements. It's in the service manual I posted.
#37
JohnnyC407 (09-10-24)
ontheroad
04-18-23 07:06 AM
