Food for thought regarding your next oil change.
Old 07-25-24, 03:56 PM
Marc780
Marc780's Avatar
Default Some information that makes me rethink everything about engine oil!
I just read an interesting comment from an LS owner who happens to live and drive in Ireland. He'd noticed that the recommended oil viscosities were completely different between US and Irish cars, and he wondered why Lexus had two sets of oil recommendations (as do I).
Anyway, here's hard proof from the 2015 owner's manual, Irish edition. Which says you CAN use 5w-30 or even 15w-40 oils if you want to (especially if conditions call for a thicker oil).
I'm trying to think of one good reason not to go by these recommendations instead of those for American cars?
Meanwhile the heaviest oil weight recommended in American LS460's is 5w - 20.
Old 07-25-24, 04:39 PM
Dave144239
Dave144239's Avatar
The temperature in Ireland rarely, if ever, gets down to 10F/-12C, so you don't need the lower viscosity on startup.
Old 07-25-24, 04:53 PM
Received 1,207 Likes on 896 Posts
The US manual MUST recommend ONLY the exact weight of oil that will get you the MPG rated on the window sticker or better, the car was tested for MPG on 20 weight so we get stuck with using 20 weight. The 20 weight is more sensitive to heat, and fuel contamination but since stateside MPG is so prioritized that's what they went with.
A more extreme example of this is the JLR 5.0 Supercharged engine, here we get a recommendation of 0/5W-20 and over 10k change intervals.....and these engines are known to blow up and kill rods/chains etc. That's because when you move to a more appropriate for the heat/strain/load oil like a 0-30 you lose 1.5-3 mpg and we can't have that! My dads L405 has 73k miles with a new engine installed at 67k due to oil failure, fantastic way to save the environment by requiring a new engine every 70k or so right!
Marc780 (07-25-24)
Old Today, 06:19 AM
THEunderPSI
THEunderPSI's Avatar
^Yep. The recommendation for such thin oils is based purely on mpg's. I run Mobil 1 European 0w-40 in all my gas engines. Great oil.
woodranch
RC F (2015-present)
380
10-08-23 02:59 PM
AMIRZA786
05-17-22 02:11 PM
KingR413
09-16-21 03:06 PM
Chaos236
09-16-19 05:22 AM
ja1
Maintenance
02-23-19 09:41 PM
Quick Reply: Food for thought regarding your next oil change.
