Radio Slow to Boot
I agree that that the radio module may be overheating and failing. I did operate the nav unit while it was in its boot limbo, nav was available and operated. I didn't set any destination to see if it would prompt me, but it wasn't slow or inaccessible. Does anyone know of any tests or checks to perform? The HDD I could scan with my PC to check its health, but any info on testing/diagnosing the radio assembly is greatly appreciated!
Bare dash
Radio/CD assembly
Monitor assembly
Helpfully this helps spark some insight into these modules and their issues. I have not called United Radio yet to get their insight into the issue. Hoping to gather more information so I can better describe what's going on.
Thanks again everyone for the help!
The main reason you should not use an AGM battery is that the flooded cell charging system has a higher “float voltage” and will over charge an AGM battery. You might feel of your battery case to see ir it is getting unusually warm.
Despite this being a possibility, why would this only happen in summer temps when the car has sat in the heat for some time? I'd think if the battery temp is rising and causing issues, wouldn't it cause more issues once the car is at operating temp under the same conditions?
In the morning commute to work when its cooler, the radio usually has no issues. By lunch time and the temp has risen, especially inside the car (obsidian color). The radio likely doesn't boot until well into my drive/lunch. Similar for end of the day in summer time. Once winter and fall has come around, the issue goes away. Rinse and repeat for the seasons.
I understand the battery is not exactly the battery type it came with, but even a battery likely doesn't have this much sway on one specific module under specific conditions. Navigation (minus audio/ voice commands), HVAC, amplifier monitor assembly all work normally when the radio is in this boot state. I don't have any other issues with anything else.
The only real thing I could think of is the module is failing or potentially a communication/wiring issue. The only reason I doubt the latter is because the radio works fine once it's on with no input lag or input errors. The radio doesn't have issues once it's finally running. Audio is clear, responds well and I've never had it stop working once it has finally turned on until the car is turned off and has sat for some time.
lili43 (09-07-24)
I'll take the temperature of the battery cold and hot throughout the next hot day or so. From what I could find on google, this battery has a 13.6-13.8V float charge while most flooded lead acid batteries have 13.5V. I'm unsure if I'm understanding exactly what your saying on this one, so I may need to crash course this a bit.
JFNash
12-04-10 12:40 PM
