Electric Power Steering
Within the past two years, many cars have moved to incorperating electric power steering. Most reviews have criticized the unnatural feel of electric steering. Although, I have heard less criticism about the steering in the LS460. Why does electric assist feel more artificial than hydraulic assist?
Actually, I think the most "neutral" feeling electric assist is the BMW 3 series and the most artificial would be my Prius. I liken the Prius' electric assist to my Logitech Driving Force Pro GT4 steering wheel lol.
I think it might have to do with an electric motor giving assist rather than a hydraulic pump. Also, it depends how quickly the motors wants to react to a quick left-right slalom.
My Prius feels pretty artificial, and it has updated EPS, previous versions were even more so... Small European cars with EPS are even worse (Clio comes to mind)... however newer systems like on rav4 are much better, so I expect new LS to have pretty nice feel.
geared engagement with the steering rack. The electric motor on the rack can add immediate power assist at low speeds for rapid movement and at high speeds gives less help. EPS is necessary for any hybrid as the hydraulic assist would not be available when the gas engine was off. I have found the EPS to be faster and smoother when going through a tight turning course and it doesn't stutter from any fluid cavitation. The inertia in a Lexus steering system is less whether it is fluid or electric when compared to its Euro counterparts. This is by design and why parking is not a chore in a Lexus. EPS is also necessary for any Lexus that has VDIM. In addition to controlling the ABS, TRAC, VSC, EBD and BA it can steer the car up to 2 degrees to maintain stability. Lastly EPS is needed for the advanced parking guidance system which will be featured in the LS460L which really makes parking a new experience!
On the LS460L's touring package which will come later there will be VGRS (Variable Gear Ratio Steering) This adds a unit in the steering column that accelerates the movement of the steering rack when turning at slow speeds and retards it when going at fast speeds. This is used in the GS430 and GS450h models and also the LX470.
Rock
Rock
i got to check latest info on how lastgen EPS works in Toyota to get better idea though...
Benefits are less power drain, so more power, less consumption, better durability and advanced features (connection with VDIM/VSC, parking, variable assist, etc)...
Rock
Rock
spwolf, lemme know the results of the findings.
will do... My prius definetly doesnt feel like there is any connection anywhere :-))))))))). Which is actually good, if I go over bad roads... Then I think something is wrong with my Rav4 when I can feel the rocks on the road :-).
