Loading music onto HDD
Anyone know how to do it? Before I pull out the manual to figure it out. I tried loading an MP3 CD and then bring up the HDD menu and it just sits there and there is no button on the screen that says to load the music to the HDD.
I have download plently of CDs. It did not recognize only 1 and it is the latest CD from Rod Stewart which I find funny since it is so new.
As far as MP3s. It should work the same way.
Are they burned to a disk, or are the files copied to the disk? That would make a difference. I am sure you must burn the songs to the disk.
In any event, if you put in a CD the player will read it and play it. There is a button in red that says "rec" If you want to record the CD, then press the button and it will ask if you want to record all the tracks, or just some. Very simple. It also has a fast record. I would say that a full CD would take around 7 or 8 minutes. I haven't timed it, but that is what it seems like.
About how many CDs can fit on the HDD? I know an exact answer isn't possible, but for those of you guys that have done this, about how many would you say would fit? The reason I want to know is--it will determine exactly which CDs I will start putting on.
Rock
