New! Just figured out how to access Bluetooth, Video, Satellite screen on LS460
Old 07-02-07, 02:35 PM
kburns7777
kburns7777's Avatar
Cool Can I watch a DVD while driving?
Is there some way to bypass the control preventing me from watching DVDs while driving? I want my passanger to be able to view a movie.
Originally Posted by hybrids14
A lot of information is here, but mostly for informational purposes. If you're looking for TV, Nav, DVD control while driving. http://www.datasystem.co.jp/ has a system out for TV only and TV-NAV, but is only available for the Japan model. I'll try to bug my stereo guy asap and force him to reseach on this so I can watch DVD, TV, NAV while driving.
Old 07-03-07, 07:55 PM
sjpobox
sjpobox's Avatar
Originally Posted by justfixit
This is accessing the Diagnostic Check Mode. This is the same as:
Touch Display
Touch upper left corner, lower left, upper left, lower left, upper left, lower left. This enters a diagnostic mode to check for LAN codes, available GPS satellites, touch screen check etc. This has been available since 1997.
No override available there. Somewhere else maybe
If your having issues with blue tooth not sounding loud enough we use this function to access the blue tooth features. Push the blue/tel button, the button all the way on the bottom and you can access the volume of calls outgoing and incoming, we set the first one to 1 and the second to 3 cant remember what the names are since I can do it by touch and memory.
Old 07-03-07, 09:42 PM
encore888
encore888's Avatar
Welcome to ClubLexus! At this time, no one has yet discovered how to engage an override for the motion lockouts on the LS 460, and even then it's not necessarily the case that the video will show outside of Park.
However, for other Lexus models an aftermarket procedure cuts an internal wire which feed the motion lockout info to the NAVI/screen. That might be the only way, at your own risk, to do that.
LA Wheel
02-09-22 09:21 AM
herblady
GX - 1st Gen (2003-2009)
05-24-16 09:41 AM
ALIGN
ES - 6th Gen (2013-2018)
08-23-14 08:02 PM
calboy76
11-18-09 02:01 PM
Lex350
ES - 5th Gen (2007-2012)
09-22-06 11:19 AM
Quick Reply: New! Just figured out how to access Bluetooth, Video, Satellite screen on LS460
