LS460 Bluetooth glitch?
I have a couple of small issues with the Bluetooth connection between my Morotola RAZR and my LS460:
- If I'm talking to someone over the Bluetooth connection, and another call comes in, if I don't answer the 2nd call my first call is dropped when the 2nd call stops ringing. This is very, very annoying. Does anyone else have this issue with their Lexus, or is this a phone issue?
- When a call comes in, the LS460 screen doesn't show me the name or the number of the caller. When I answer the call, the number appears, but it never displays the name. I transferred my phone book to the car's phone book via Bluetooth, so the numbers match.
Thanks for any insight you can provide!
Jeff
Jeff
I'm having a same issue with my Sprint TReo 700p. According to Palm, BT of the Lexus is not compatible with BT in my phone. It pairs fine and I can talk w/out any issues, but when the call comes in I don't see the correct name. In my case, it's not the car's problem. It's a compatibility issue with Lexus/Denso and BT on my PALM. You may have a same problem. Check with Motorola.
To correct the dropped call issue, you need to disable call waiting. With Verizon this is done at the network level so you need to call them. I believe that with other carriers it is done on the phone via the menus.
I can't believe they still have not fixed this issue in the new Flagship LS!!! I have a 2006 GS, razr v3, under Cingular. Call waiting, no matter what I do, drops both calls. It is a Lexus software problem, don't let them blame anyone else. I have not choice but to disable call waiting.
WOW, that is ridiculus that they make you disable such an important feature of the phone to use bluetooth. Funny how my $39 headset can work fine but a $70,000 flagship can't!!!!!!!!!!!
Go Nokia; as long as the contact's name is in the car's phonebook, it appears on the screen, and I have not had issues with dropped calls. Every phone is different, and I doubt Lexus can anticipate all the intricacies with the plethora of cell phones on the market today, and tomorrow. Try a different phone that works; don't blame it on the car.
