Caller_Id on LS460 Solved
I wasn't getting the names when people called me and sometimes not even the number. I went to Lexus and they told me to change my phonebook in my car and put a 1 in front of all the numbers. I put the 1 plus area code plus numbers and now anybody that calls I see their name and phone number if they are in my phonebook. That's the first time I have been able to do that.
I hope this helps someone else.
Thanks for the post. I was just getting started inputing my phone book and tested it and I was only getting number not caller name popping up. That tip worked for me![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
BTW, I have Cingular w/ Motorola Razr V3
There was a whole discussion and resolve with this on another post within this LS forum...sorry you went through the trouble. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
https://www.clublexus.com/forums/sho...d.php?t=277643
Yeah I know. I tried that fix but it didn't work. This one definitely works. That fix was to take away the 1 and this one that works is to add the 1..Oh well whatever works huh?
I am with Verizon...the fix worked as noted in the previous thread displayed in the link above. It may be more relevant to the phone that the service provider...it appears either adding or dropping the "1" prior to the area code is the solution but the entries in your phone need to match what you enter into the phone book (if your phone does not work with the auto transfer feature).
