LS 460 L Door Unlock settings needed..
1 Post
hello guys ,
I live in UAE (GCC*)
Now is it possible doing the following without going to an LS dealer:
1-Wirelss remote control:
Unlocking operation: The deafult is set to Driver's Door unlocked in one step, all doors unlocked in two steps i want to use the cutomized settings which is all doors unlocked in one step which i shall say default for your cars.
2-Door lock:
Opening Drivers's door unlocks all doors:is set to off i want to enable this function
3-Door lock:
Unlocking using a key:again Driver's Door unlocked in one step, all doors unlocked in two steps i want to use the cutomized settings which is all doors unlocked in one step which i shall say default for your cars.
Any help would be gr8
*:Gulf Cooperation Council
2-Door lock:
3-Door lock:
You have to bring it to the dealer, but the first time its free.
UAE, you can actually do it yourself with the remote. Hold it within six inches or so of the door and hold down the lock and unlock buttons simultaneously for a few seconds. When it beeps, it will change the setting (1st drivers door only, then both front doors, then all 4, then back again). This sets both the remote, and the touch unlock. I think it applies to the key unlock as well, but I've never tested it.
Cheers
Cheers
1 Post
Thanx Man ill give it a shot in a few althought the manual says:
Your vehichle includes a variety of electronic features that can be personalized to your preferences.Programming these preferences requires specialized equipment and may be performed by your lexus dealer.
