NEED HELP!!! NEW LS460 owner (lost only key)
Old 08-19-07, 10:22 PM
  #31
rominl
exclusive matchup
rominl's Avatar
Originally Posted by Nospinzone
Yes, there are keyholes. They're tucked underneath the front door handles. You don't actually see the hole because there is a plug to keep out dirt and moisture.
http://auth.owners.lexus.com/lexusow...html&locale=en
oh, that's interesting, never knew about that.
thanks for the info
Old 08-20-07, 04:25 PM
  #32
encore888
encore888's Avatar
Yeah the new push-button SmartAccess Lexus cars have the removable handle piece in case the key fob battery fails, etc. and the mechanical key is needed to unlock the vehicle.
Old 08-22-07, 05:20 PM
  #33
sjpobox
sjpobox's Avatar
They break easy to so if yours does then have it warrantied out.
Old 08-23-07, 09:14 AM
  #34
DanceEagle
DanceEagle's Avatar
It ends up the convenience of the new keyless system is offset by the giant pain the butt if you lose them. Not only terribly inconvenient but expensive too.
Four Tips: One: You didn't lose the key inside the car. If you did everything would work. Second, the key is probably very close to where you parked the car. Three, Murphy's Law specifies you will find the key easily once you get a new key. Four, when you find the key it will be in the last place you look. :-/
ppower
08-03-18 11:58 AM
deadmilenk
03-16-18 11:47 AM
LS2k
07-14-12 06:38 PM
TheRealtor
11-15-11 05:03 PM
bs0dxi
05-04-11 01:29 PM
Quick Reply: NEED HELP!!! NEW LS460 owner (lost only key)
