Lowering the Air Ride
Old 11-08-07, 08:54 PM
JKarger
JKarger's Avatar
Default Lowering the Air Ride
Has anyone done this yet? I have been told that there are two diffrent ways to do it. 1. with a links system and 2. with a data system control module. Anyone?
Old 11-08-07, 11:09 PM
GSXOTIC
GSXOTIC's Avatar
I have the Data System controller installed. I think a few others also have the same unit installed and work beautifully.
Old 11-08-07, 11:33 PM
rominl
exclusive matchup
rominl's Avatar
if you have stock air suspension, data system is your friend. cheap and works super well
Old 11-09-07, 07:39 AM
ironhorse
ironhorse's Avatar
what is the data system? pics and info please
Old 11-09-07, 08:00 AM
Gojirra99
Super Moderator
Gojirra99's Avatar
Some pics : http://sr1.clublexus.com/forums/showthread.php?t=295692
Old 11-09-07, 08:02 AM
Gojirra99
Super Moderator
Gojirra99's Avatar
datasystem with regular Lexus LS Touring wheels : http://sr1.clublexus.com/forums/show...tem+controller
Old 11-09-07, 08:27 AM
ironhorse
ironhorse's Avatar
dumb question, I have the 2008 LS460, is air suspension on all the 460's or is it part of a package? Do you know the cost of this lower system.
Old 11-09-07, 08:40 AM
GSXOTIC
GSXOTIC's Avatar
data system is a lowering controller which allow you to lower the air suspension equipped vehicles (depends on applications) at a press of a button. The module is a plug and play unit that goes behind the dash into the air suspension ECU. The actual controller is about a size of cigarette box with LCD display.
https://www.clublexus.com/forums/sho...ht=data+system
Note the data system in the about link is for LS430. ASC680L is for LS460L/600hL
Old 11-09-07, 08:43 AM
GSXOTIC
GSXOTIC's Avatar
If I am not mistaken, LS460 (at least 07') does not come with air suspension. I don't know about 08'. I believe the system is retailed at $1200 but I am pretty sure if you shop around you can find good prices.
Old 11-09-07, 08:53 AM
Gojirra99
Super Moderator
Gojirra99's Avatar
I think even for 08 models, the air suspension is an option only for the LS460L, not the LS460.
Old 11-09-07, 09:12 AM
rominl
exclusive matchup
rominl's Avatar
correct, i don't think swb has air suspension.
one good reason to go for lwb if you want to lower your car so much cheaper
Old 11-09-07, 11:33 AM
misterk
misterk's Avatar
to gsxotic:
are you saying anyone with a 07 ls460 swb can add the stock air suspension for 1200.00 after buying a car that hasnt? if so, that is great news...
Old 11-09-07, 11:36 AM
RAMPAGEsd
RAMPAGEsd's Avatar
another cheap way of lowering your car with out the datasystems controller is readjust the leveler arms on the suspension.
LexLuv8000 (08-26-22)
Old 11-09-07, 11:46 AM
rominl
exclusive matchup
rominl's Avatar
Originally Posted by misterk
to gsxotic:
no, he meant the air controller retails at 1200 but you can get it for much cheaper.
you don't even want to think about adding factory air suspension to the swb. i can't imagine the cost
Old 11-09-07, 11:55 AM
misterk
misterk's Avatar
thats what i thought...back in the boat of waiting for springs again i guess...thanks
Quick Reply: Lowering the Air Ride
