Tire Pressure: Is 39 PSI too much?
I have put 39 PSI into my LS all around. I like the way that it handles and it gets a little better gas mileage but this is higher than the sticker suggests. Are there any serious drawbacks to this especially as it relates to safety, stopping distance, etc? Also, will the center of the tires wear out much quicker at this level?
You will find it easier to do 360s in a parking lot... ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
If you're just driving at city speeds, it shouldn't be a problem. At highway speeds however, the tires bulge out from the centrifugal force applied, and tire wear will increase, especially on the steering tires. You will "marginally" lose some traction going around corners though. So it really depends how you use the car. You're certainly won't get any blowouts or anything like that.
If you are talking about 39psi COLD pressure, keep in mind it will rise to maybe 43psi or so in hot weather or after driving at freeway speeds for awhile. That puts it near the maximum pressure for most car tires, and that's not a safe place to run your tires.
OTOH, if you're talking about the tires reaching 39psi after driving for a long time, that's not overly excessive - especially in the summer - although it's a little high.
Excessive tire pressure will cause abnormal wear and will affect traction. I personally think it's a good idea to follow the car manufacturer's recommendations. You aren't going to save any meaningful amount of gas doing this, and you may be endangering yourself.
Thanks for all of the responses!
It is a cold PSI so you are right, it will rise.
Lexus delivered the car to me with higher PSI than suggested (38) so that is why I thought it was probably safe to take this approach but maybe I should take it down just a touch.
actually, lexus delivers cars with higher psi so the cars are easier to roll, etc... at the port. BUT the dealerships are supposed to check the pressure AND correct them back to the spec.
39 is ok, but for stock 18s they are way high and not necessary. you are mostly degrading the ride
Yeah, the Lexus Dealer did not reduce tire pressure after it was delivered to me. I was driving and I thought the ride was harsh, I was scrolling through the display and saw the PSI was 39. The next morning I reduced the PSI to 33 PSI, the manufacturers recommendation....BIG difference, ride much smootherat 33.
The dealer replaced my wheels with chrome wheels and still delivered the car to me with 40 psi as they do after each service. I notice the ride right away and reduce the pressure down to 33 the next morning.
Dave Mac
Dave Mac
the reason your cars always come back with higher thatn "recommended" pressure is because the techs know that recommended pressure wears out the edges of the tires more. yes it rides better butyou'll be wearing out tires faster.
the heavy weight of the car puts a lot of pressure on the edges of the tread during cornering. more air pressure helps to keep the tire from deforming and wearing badly.
You should be OK with 39 psi in PA (its not like you'll be driving there at sustained speeds of 90 mph in 100+ degree temps!)
It will give you a harder ride, but fuel economy and tire wear will improve slightly. Check the wear regularly. If you are overinflating the tires, they will wear in the center more than the edges.
The reason the dealer stores cars with high pressure, it reduces flat spotting the tires. I run 35 PSI in all four tires. You will notice a stiffer ride with more air. My car was delivered with 45 PSI in all tires. I think 33 PSI is too low.
Craig
Craig
I've always run recommended pressures (and sometimes less), and my tires always wear evenly across the treadwidth. OTOH, I've seen lots of tires run at higher than recommended pressures and they usually show accelerated wear in the middle of the tread.
I guess you can run them wherever you want, but just know what you're getting into when you do. Or go to a reputable tire dealer and ask someone there who knows about such things (not the grunt changing tires).
