View Poll Results: Does your LS460 have wind noise? (you can pick more than one)
YES, my 2007 LS has definite wind noise as described.
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
14
40.00%
YES, my 2008 LS has definite wind noise as described.
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
8.57%
NO, my 2007 LS has no wind noise as described.
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
5.71%
NO, my 2008 LS has no wind noise as described.
![](https://www.clublexus.com/forums/images/polls/bar5-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar5.gif)
![](https://www.clublexus.com/forums/images/polls/bar5-r.gif)
17.14%
Yes, my LS has some occasional outside swishing sounds.
![](https://www.clublexus.com/forums/images/polls/bar6-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar6.gif)
![](https://www.clublexus.com/forums/images/polls/bar6-r.gif)
16
45.71%
Multiple Choice Poll. Voters: 35. You may not vote on this poll
LS460 Wind Noise Fix (merged threads)
Nice to read the posts and the limited action that appears to be starting to take place. I too have the wind noise and am watching the posts for when I bring in my car next month for it's oil change. Thanks again!
It will take 2 full tanks of gas for me to notice any difference, but I can tell it shifts on little higher rpms which is good, it feels even smoother.
It's important to note that on the service invoice it was written that "car has a system to disingage transmission torque converter when stopped for an extended period of time. System is operating within range". Even so, the software upgrade was done, and it's TSIB #TC004-07. This means "updated files for ECT ECU".
One thing I can tell: after the upgrade, the screen turns to the map faster right after I press the "I agree" button. It used to be a somewhat slow transition, now it's instant.
I'll post updates on the transmission after I burn two tanks of gas.
What kind of an estimate did the dealer give you to make the wind noise repair? My dealer said the Field Engineer told him to allow 3 days for the fix; I questioned what all the fix involved because that seemed long to replace the glass and add some insulation and the dealer agreed but wasn't sure because he said the TSB is still in draft form and he hadn't yet seen it.
My dealer told me to bring the car in early in the morning and I could pick it up that afternoon. He thought it would only take a couple of hours. BTW, I live 110 miles from the dealer.
Craig
Craig
Interesting; I didn't have a warm and fuzzy about leaving my new 460 with only 2300 miles on it at the dealership for 3 days without them being able to justify 3 days worth of work. One day seemed reasonable but 3? Right now I'm waiting on the final TSB so I can see what the fix will involve and what the estimate to repair will be. I'm sure I'm not alone in waiting to hear from those of you that will have the repair to find out what it involved and if it mitigated the wind noise.
Also, the hickup from a dead stop was starting to get to my nerves, so I pointed that out at the dealer and they upgraded the software.
Thanks
Super Moderator
If there indeed is a fix in place that will resolve this issue completely, I would think the factory in Japan should know how to build those parts of the car by now, so the 08 models should be expected not to have this issue ...
I just received a call from my dealer. They will replace the windows on July
24th. The tech is going to replace the glass when the Lexus field service rep will be ther to show him what needs to be done.
I hope this is the end to my wind noise... I will let everyone know if this takes care of the problem... I hope to have the transmission update done at the same time...
Craig
Craig
