View Poll Results: Does your LS460 have wind noise? (you can pick more than one)
YES, my 2007 LS has definite wind noise as described.
14
40.00%
YES, my 2008 LS has definite wind noise as described.
8.57%
NO, my 2007 LS has no wind noise as described.
5.71%
NO, my 2008 LS has no wind noise as described.
17.14%
Yes, my LS has some occasional outside swishing sounds.
16
45.71%
Multiple Choice Poll. Voters: 35. You may not vote on this poll
LS460 Wind Noise Fix (merged threads)
#541
#543
All I hear is an occasional swishing sound as the air tumbles over the car and past the rearview mirrors, trim, etc. I truly can't call it wind noise, since that to me means a whistling or roaring sound like you'd have if your window were cracked open a tiny bit.
As others have noted, it's partly because the rest of the car is so quiet that any sounds that might otherwise be drowned out are now perceptible.
The sound that I can hear, though, isn't anything I'd consider abnormal or indicative of anything wrong, and I have no plans to have anything done about it unless it gets 'way worse than it is now. To me, it's just a consequence of moving a big object through the air.
That being said, I'd say it's been resolved, at least in my car. BTW, mine was a November 07 build, and came with the laminated side glass.
#544
I got my LS460L yesterday and it has the problem .. it is November 2007n made
The noise occure from both front windows (they r doubled already) when they r fully closed, but when i just hit the lowering button little bit the glas moved for about 0.5 CM and the noise completly disappear !!
I'm planning to take it to the dealer on my first 1000Km checkup. Anny one faced same problem ?? is this could be repaired??
#546
#547
More wind noise
I just got my car back from County Line Lexus, Hollywood FL. They had my car for 19 days now I have it back there is no soud difference at all, it still sounds like a window is opened a crack what would you suggest i do from here.
#548
Had something interesting happen yesterday. I slightly opened the window (and I mean slightly) going about 60mph. OMG was the noise loud - much louder than I've ever heard in another car. When closed, I don't have any wind noise problem, thankfully, but it's amazing how much turbulence and noise was created by that small air gap (no physics lectures about Pouiselle's Law, boys).
#549
#550
zz and romin, ditto for me as well. But this has to be normal. What do you expect when the air is rushing by at 70-80 mph with a slightly opened window? If my window is closed, I do not hear any unusual wind noise at all. If there is a strong cross wind, I hear a gentle "swishing" type sound, but again this is very normal. My LS430 had a louder sound with cross winds and noise in general was more pronounced on the 430.
#551
#552
Wasn't there some discussion about perhaps this (strong rushing wind noise when windows are down) is due to the aerodynamic styling of the vehicle, the way air moves around it vis a vis low drag coefficient? So long as the window lower/seal issue is not there, then the car should be fine IIRC...
Good luck to those getting their cars repaired, if they need it. If it hasn't worked, not sure maybe going to another dealer if it's very severe, or checking the efficacy of the actual repair...
#553
#554
I noticed that when i close the window( Full close ) it look like the glass is pushing agaist the door ( towards outside) and the down sealing ( rubbers )from outside moves up little( like 2mm ) and thats when i hear the Shhhhhh noise .. Its not so loud ,, this noise are coming from the wind when it hits the side Mirrors and been reflected by them to the Sealing between the door and the Glass ..
I think lexus should think about the shape of the side mirrors and make it connected to the door as it was in the old models of LS to avoid trublace caused by them
#555
