Reset 'Oil Maintenance Required' LS460
Old 09-14-14, 02:14 PM
Schutzhund
Schutzhund's Avatar
The procedure posted by onepointon works fine, but for the sake of accuracy, the owners manual page 561 says simply to hold the start button until the reset procedure completes, rather than pressing it twice.
Old 09-15-14, 07:16 AM
DJWLDW
DJWLDW's Avatar
So is the light mileage driven or is there a senior in the oil which says "hey I am dirty change me"? So if you want to run 10,000, or 7,500 miles between oil changes and not 5,000 you can just do the reset thing and the light goes out for another 5,000 miles?
Dennis
Old 09-15-14, 08:22 AM
jlawr
jlawr's Avatar
no you can't
Old 09-15-14, 08:26 AM
SBlexus
SBlexus's Avatar
Yes You can just reset the light.
Old 09-15-14, 09:59 AM
roadfrog
roadfrog's Avatar
All of this only applies to vehicles with this option. My 08 has the service system on the Nav Screen under "menu" and allows entering air filter intervals, cooling system, brakes, etc.
Old 09-15-14, 03:31 PM
SBlexus
SBlexus's Avatar
I think he's talking about the oil maintenance reset light, not the navi service menu.
Old 09-15-14, 03:38 PM
roadfrog
roadfrog's Avatar
Yep, I know. But as in my case, this is not on all cars...including mine. For example, the owner's manual states under "oil service reminder"... "if equipped". Mine is not "equipped" and when I try to follow the reset procedures, nothing happens. Furthermore, I went 6k miles on my last oil change and there was no light or message telling me to service the oil.
Old 09-15-14, 03:41 PM
DJWLDW
DJWLDW's Avatar
Mine came on after 5,200 miles or so?
Dennis
Old 02-26-16, 03:05 PM
philnshelb
philnshelb's Avatar
Default dash oil reset minder 07 460
Great worked like a charm. Interesting that this Reset isn't linked to the navigation screen reset for oil and filter.
Originally Posted by teamplayer
^^^That is correct. Make sure the Trip/Odometer is set to "trip A". With ignition off press and hold the reset button. While pressing the reset button, press the start/ignition button twice to turn ignition on. Keep watching the trip/odometer display to flash the lines (-----) until you see it flash the zeros (00000) then it'll read out your "trip A" again. Then you release the reset button.
lrosen3565
12-12-21 03:16 PM
StylinGS300
09-03-18 04:29 PM
atomarchio
ES - 5th Gen (2007-2012)
06-25-10 10:56 AM
StylinGS300
07-05-09 03:16 PM
LS4fun
07-25-05 05:35 PM
Quick Reply: Reset 'Oil Maintenance Required' LS460
