2008 LS460 Tire pressure reset button
I finally found the darn thing. It was right above and left of the accelerator pedal. It also had an adjustment **** next to it. I am wondering if the procedure has changed for reseting. Nothing in the manuals.
After you put air in the tires, push and hold the button for 3 seconds and the tire light will blink. Then it will illuminate for 3 blips and turn off. This will be the new benchmark for the air pressure. ( I think)
Look under the steering wheel down low on the kick panel above the brake pedal. There is also a control **** on there too. After considerable exploration I finally figured out that it controled the volume on the door lock ringer, and who knows what else?
Checkout owners manual page 513. It has a pic with insert.
Amendment: Went out to the car to confirm. You have to really crawl down there and then look up. It is hidden back there.
