Control Arm bushings gone...
Old 04-01-08, 12:33 PM
BUSTN
BUSTN's Avatar
Default Control Arm bushings gone...
Well, I'm having issues with the control arm bushings. Lexus said they won't replace due to aftermarket wheels. This is unbelieveable, definetly time for a change...
Old 04-01-08, 12:42 PM
rominl
exclusive matchup
rominl's Avatar
what, they wore out completely? your car isn't even lowered right? wonder how the wheel can put that much wear
Old 04-01-08, 01:01 PM
BUSTN
BUSTN's Avatar
OK, let's recap. Idler pullies went bad, ML subs blown, b pillars damaged,control arm bushings, bad brakes(replaced rotors and pads at 8k).I'm waiting to see what else I'm in store for.The car is not lowered. I could understand if I had some junky heavy wheels but A/C 3 pc wheels with the o.d's in spec, come on!
Old 04-01-08, 01:20 PM
rominl
exclusive matchup
rominl's Avatar
man seems like you got a lemon....
Old 04-01-08, 07:49 PM
allklr
allklr's Avatar
How much is it to replace the control arm bushings?
Old 04-01-08, 10:52 PM
rominl
exclusive matchup
rominl's Avatar
i am not sure if toyota/lexus has JUST the bushings. from my experience with previous lexus models, you will basically need to get the whole new control arm as replacement
Old 04-02-08, 06:23 AM
tyoung88
tyoung88's Avatar
This is really making me think twice about getting 22's with the air suspension controller. Has anyone else had problems with the control arm bushings?
Old 04-02-08, 06:49 AM
MadDawg350
MadDawg350's Avatar
Copied this from another forum I play around in and should be of good use for you with the dealer problems you are experiencing.
Old 04-02-08, 07:08 AM
allklr
allklr's Avatar
That really sucks, Are you going to try and go through corporate or another dealer?
Old 04-02-08, 10:58 AM
rominl
exclusive matchup
rominl's Avatar
unless there are real direct proof of the control arm bushings with the wheels/lowering, i wouldn't believe the dealership yet
Old 04-04-08, 08:04 AM
GS430X6
GS430X6's Avatar
Your situration is the exact reason why I allways keep my stock parts when my car is still under warrenty.
Did you keep your stock wheels? If so why not put them back on then take it in for warrenty work. Maybe try another dealer?
Old 04-04-08, 10:17 AM
rominl
exclusive matchup
rominl's Avatar
more than likely they already put in the computer that the car has aftermarket wheels and warranty gone, etc...
and that's accessible nationwide i believe
Old 04-04-08, 01:47 PM
JBrady
JBrady's Avatar
Your profile says GS400 but I am assuming you now have the LS460?
That list is insane. Take it up the corp ladder. I have to believe Lexus would be concerned with such problems.
realsync1
12-14-22 11:00 AM
tedsterb
Suspension and Brakes
02-02-16 10:31 PM
NEORX30GUY
RX - 1st Gen (1999-2003)
11-16-15 05:36 AM
nadude98
GS - 1st Gen (1993-1997)
12-23-13 09:07 AM
prep2
03-29-06 12:15 PM
Quick Reply: Control Arm bushings gone...
