Newbie question need help (power door closers)
Hi, I am just wondering if the doors on the LS 460 close like the trunk does where u just tap it just a little and it close it self... (Like the mercedes s500 does). If so how do i turn this features??? Also, does anyone know how to turn on the auto window on the driver side back on???
Yes they do come with the power door closers and it is on all the time and by the way the trunk closes with a touch of a button, u don't need to bring it down. All four windows come with one-touch operation all you need to do is press or pull harder for it to come up all the way on its own.
- Press and hold down the "Down" button until the window goes down all the way, BUT KEEP HOLDING THE BUTTON DOWN for about 5 or 6 more seconds.
- Then, raise the window by pulling up on the window button and holding it for about 5 or 6 seconds after it goes all the way to the top.
That should re-program the window controller.
I am having trouble with the door that does not close itself on the first click for some reason like the trunk does... Is there a switch I have to press or something to click to activate it???
No there is no switch its always on. Your door will not close by itself the power door closers work only when your 5-6mm (0.2 inches) open. Yes I also agree that the power door closers are much better than the one in the S-Class.
Will any of the other doors function properly?
I ask this because I have seen issues on two vehicles in the past few months. It seems that the weather seal that goes around the door can cause the door not to close on its auto function. On both occassions we replaced the weather seal and it fixed the problem. However, there are no updated parts available, so who knows if its a bandaid fix. If it becomes an issue I am sure they will issue an updated part.
If you are having trouble with the system, take it to your local dealership and see if someone can look at it for you.
I don't want to make another thread, since this is almost the topic I am looking for.
here is my question:
my car was lock, I stand out side the car with my remote, I press and hold the unlock button , and the car is unlock, all the windows go down, and sunroof open (cool thing). But when I press and hold the lock button, the car is lock but the window DID NOT roll up and the sunroof DID NOT close. can anyone tell me why, or is it suppost to be like this? (notice that when I am doing the same thing with the button on the door handle, the windows roll up and the sunroof close itself.)
maybe it could be US spec, but euro spec closes everything up. Just sometimes, happen that u misshold button and it seems that it doesn't work, but it is just not holding press button firmly..
None of the doors work... Was it an extra feature that I had to buy? Or does it come standard in all Ls460? I bought the car pre owned and I saw my friends Ls460 and her door close, so now I am trying to figure it out. Because I know the trunk close if you just close it to a clip and it closes it self, but not the door.
It is an extra option and it also comes standard as part of certain packages depending on when the car was built and which region of the States was the car imported for. FYI when you go to Lexus website the first thing they ask you is your zip code. I was looking at IS350 and when I used a zip for California I got different items in a package then one meant for Texas.
