Hmmm ... odd tire wear so soon?
As far as SAI, I need to research what exactly this is.
Ill see if I can get back to you sometime throughout the day to let you know what exactly that number is. If may just be something the computer checks for, but in fact isnt adjustable. Either way its damn close to the spec so I wouldnt stress on it too much, the important numbers look pretty good.
I asked one of my co-workers and he wasnt sure either. We have a guy here that specializes in alignments, I personally just do not perform them. I would agree with rominl that your toe was pretty far off as the numbers suggest.
SAI= STEERING AXIS INCLINATION
Reading the following might make sense to you, but it's all Greek to me.
http://autorepair.about.com/library/...bldef-748a.htm
Haha, I know I know.. Its been about 2 years since I have done an alignment to be honest...
I just pulled out our Lexus Steering, Suspension, and Handling book from a class a long time ago. The way I understand SAI (steering axis inclination as stated) is the distance between the steering axis, and a vertical line drawn through the wheel.
![](http://home.earthlink.net/~goodspeeds/axis.gif)
It is used to determine possible damaged components that cannot be diagnosed with camber/caster/toe. It also has a direct affect on your steering wheel coming back to center when making a turn.
I will not lie, Im still a little fuzzy on the technical aspect of it. On my lunch break I am going to take a print out of your specs to my alignment guy and let him take a look. I think the Cross SAI is a little out, but I may be wrong and/or it may not be adjustable. Ill get back.
