LS460 Wind Noise Fix (continued discussion)
#796
a little thread revival but this week I lowered all of my windows and noticed one of my weather strip in the rear window looked different so after careful comparison I snapped it back into the right location and bought some mequiars m40 for vinyl rubber and etc. and cleaned all of the weather stripping on the car including the doors windows and such and now my car is tomb quiet! I also did the other fix but that was last year and I got to say that the car is quiet again. Check those weather stripping on the car for anything pinched like stated before.
#797
cross-winds
#798
This is my first time on here so I hope this message gets to you Jim. I have read your entire post about the wind noise. I bought a 2008 LS 460 about 6 months ago. The wind noise was driving me crazy and finally I googled it and came across your fix. I was amazed at everything you tried in communicating to Lexus. I have ordered the GE-280 Sealant. My question is, Has your fix been modified to not include the metal patch? Is Lexus actually doing something about this now or do I need to attempt your fix?
Thanks for your time,
John
John
#799
John,
I have not seen any indications that Lexus is doing any sort of repair for the wind noise that is caused by the separation of the triangle-trim on the doors. Anything that would provide a good seal under the trim would be okay and there are lots of ways to do that. The metal patch is one way to do it and it is certainly easy to do and very effective.
The most current instructions for the DIY repair that I suggested are here in the #1 post: https://www.clublexus.com/forums/ls4...noise-fix.html
Please check the Private Message feature on this site for a message.
#800
Thank you encore888 for the TSIB link
TSIB information: http://www.lambros.net/2007LS460L/tsib/
I was experiencing a creak, tick or rattle noise from the upper and lower portion of the windshield, which is known as L-SB-0090-08 (windshield tick noise)
THANK YOU
THANK YOU
#801
Jim,
I have read you instructions on the repair for the wind noise problem and your attempts to get Lexus to acknowledge the problem. It's clear they do not want to acknowledge the problem and have to fix thousands of cars. With that said, have you noticed that Lexus has redesigned that black triangle piece on the 2013 model year? My question is, do you know if this newly designed piece is interchangeable for use on the previous generation LS? I have not driven a 2013 so I do not know if the new design has fixed the wind noise issue. If it has, that would be an easy fix if we could just swap out the piece for the new design. I have a 2010 LS460 AWD and have a slight whistle noise on the drivers side. Any help you can provide would be greatly appreciated.
Thanks,
Walt
Thanks,
Walt
#804
Here is a picture of this part that was posted a while back: https://www.clublexus.com/forums/ls4...ervations.html
Here is another comment about the new trim part: https://www.clublexus.com/forums/7705119-post778.html
#805
Well, I was told it would not fit by the service manager. He may be wrong. I looked at a showroom 2013 and the part seemed smaller to me so I took the SM word for it. Wonder if anyone has actually tried it. I may see how much the part is at Sewell online parts and if reasonable try it for the heck of it.
#807
I guess the only way to be sure is to have the parts manager bring out both new and old and compare them side by side for size and registration pattern. I did notice on the 2013 that not only did they add the vortex fin but the piece is somewhat raised in the middle and not flat like the old version. If anyone tries the new version or is able to view them together please let me know your results.
Thanks,
Walt
Thanks,
Walt
#808
Hi,
The new 2013 part do fit...read post here:
https://www.clublexus.com/forums/ls4...2013-cars.html
