Replace Parking Light Bulb
If you are referring to the "Nike Swoosh" shaped light at the corner or the light cluster, then I believe you have to pull the whole assembly out to access it. I think it is a LED bulb, so if yours is burned out, you should be able to have it replaced under warranty. If you're trying to change it to a different color, then you're on your own - trial and error. I personally would attempt it, but there are no guides that I know of around. The factory service manuals should cover that, but they would probably cost more than getting your dealer to do the replacement.
