Help with 22" Wheels
I recently installed 22" wheels on my LS460L. I keep getting an error message on the dash that says have your dealership check the tire pressure monitoring system. I've selected the change tire button several times and after riding for about 20 minutes the message comes back. Any ideals on what the problem is?
Are your new wheels TPMS compatible? and if so were the sensors transferred? There is a possibility that if they were transferred one may be damaged? I would just work down the list starting at reseting the tire pressure button. Also how much psi are you running in your tires.
I had brand new Lexus TPMS sensors installed on my 20" wheels and got the same error message. The reset button below the dash didn't fix the problem. I had to take it to the dealership so they could re-initialize the TPMS system with the new sensors. I think it cost me about $75. PITA, but warning lights drive me nuts!
Definitely interesting. Just to be clear, I did not have my factory TPMS sensors switched to the new wheels. I purchased an additional set of sensors that were installed on the new wheels. I wonder if the factory sensors would have worked properly if I had just re-used them? Could that be the difference?
Ah now this makes sense. Whenever you install new sensors they have to be re-programed to the cars computer system. My Zone wheels used the factory sensors with no issues. Hope you are able to figure it out.
NINEZeRO
Wheels, Tires & Brakes Forum
04-26-06 07:12 AM
foofighter
07-25-05 11:38 AM
