Radio / NAV Removal Procedure Needed
We are trying to install an IPOD intergration kit in a 2007 LS460L with NAV - looking for radio removal procedure. Is there one posted out here somewhere? Thanks! Tom
After you remove the gear shift ****, console cover, the ashtray assembly and the two bolts that anchor the Radio, the front view of the radio (near the bottom) looks like this.
|___/<------------------------->\_____|
You can use a wide flathead screwdriver behind the "tabs" where the arrows point to "pop" out one side of the radio and then the other. Then it's real easy to pull out the radio.
Good Luck!
Good Luck!
