Scrapes on Bottom Front Bumper
To my horror, I have discovered signficant scrapes at the bottom front bumper - caused probably by normal parking against curbs on city streets. There was even a small. but not insignifcant dent. They cannot be seen unless one bends down to look - quite low, but they are not attractive. I was thinking about putting a bra on the front of the car, but I don't think that would help. Any ideas or similar experiences? I would hate to have it repaired and then have it happen again. The problem is that I don't recall any particular incidents where this occurred. My car is not lowered in any way. It does have air suspension and I guess I could put it in the high position. Thanks.
If they are minor scratches you may be able to buff it out with a machine buffer but not all of them will come out (most likely). A bra would help some but it probably won't eliminate it and it may compromise the appearance of your car depending on the type. The best way to off set this is to watch where you park (assuming that it is from poor parkers).
This is the reason why my SUV's are the only cars that go into the city. It is easier for the cars to see how much room they have and they are less likely to allow their hood or trunk lid be hit.
If it is really low then it probably is from curb damage which would be your fault (or that of a valet).
I got some scrapes on mine (from a small boulder I didn't see) and I bought the touch up paint. It worked remarkably well. I mean I can tell its there, but no one else ever notices.
...also I suggest being careful on sharp dips in the road, the angle/nosedive can scrape the bottom front bumper. At least there isn't as much nosedive as some FWD cars...
robinlt
CT 200h Model (2011-2017)
09-06-11 01:39 PM
