Transmission "lag" when decelerating
Old 08-26-08, 02:19 PM
lexier
lexier's Avatar
Default Transmission "lag" when decelerating
This is truely a great forum and thanks to ALL who have contributed to it.
It helped me to make a decission to buy a 2008 SWB. I have owned a 1994 LS400 and a 2003 LS430 and now love the LS460.
I have a question if anyone has noticed a problem with the LS460 pulling back or "lagging" when decelerationg - like the brakes are being applied, when they are not. I have given it 1000 miles, hoping that I would get used to it or the car would "learn" my driving habits. I do not drive it hard, and it seems to happens most in the 30MPH - 40MPH range. The dealer said that everything looks normal. Any thoughts?
Old 08-26-08, 02:30 PM
Johnny
Johnny's Avatar
Your transmission has a mind of its own - literally. When your car decelerates, it will down shift by itself (as directed by its ECU), without braking or manual shifting by you. Most cars now have that feature, but on some cars it is more apparent than others, and the LS is one example. I notice it on mine as well, and if there was anything abnormal, it would show up on your dealer's computer's diagnostic check report.
Old 08-26-08, 02:47 PM
lexier
lexier's Avatar
Thanks for your reply Burnaby. It just seems as if it does not "coast" very well when I lift my foot off the pedal at 40MPH , and as the speed drops
down to 30MPH, it frees up and seems to coast normal. Do you have the
same experience?
Old 08-26-08, 05:25 PM
Stoks
Stoks's Avatar
I have an 07 LS460 SWB with 11k miles on it. My car coasts very easily. In fact, I find myself having to tap the brakes to slow it down while coasting down slight inclines in order to avoid speeding.
I have noticed that every once in a great while, the car seems to catch gears going down an incline and it doesn't coast as easily. But, that doesn't happen very often.
My understanding is that the car has been engineered to coast pretty easily in order to boost mileage, but I'm not certain about this.
My experience is definitely different than yours.
Old 08-26-08, 06:36 PM
lucasb7
lucasb7's Avatar
It seems as though I heard something about it doing that when in the PWR mode. At least on the GS that is.
Old 08-29-08, 08:49 AM
MythBuster
MythBuster's Avatar
I have noticed the same when I use the power mode.
I use the power mode to reduce the coasting and save breaks.
Old 09-06-08, 11:51 AM
joedaddy1
joedaddy1's Avatar
i have the same issue.. but not sure if it's normal.
Old 09-06-08, 03:50 PM
Nospinzone
Nospinzone's Avatar
Myth, I'm not sure that is the wisest way to reduce wear on your brake pads. In the long run the extra wear and tear on your transmission may end up being more expensive. That's just an opinion, I can't back it up with solid evidence.
Old 09-06-08, 06:42 PM
lexier
lexier's Avatar
I do not use the power mode and it still happens. When I get up to the
speed of 40mph, I then lift my foot off the gas and it drops to 30mph in
approx 10 - 12 seconds. I was able to drive another LS460 and it doesn't
drop to 30mph for at least 25 - 30 seconds. (this has been my minor test,
as it just doesn't fell correct) The dealer is trying to tell me that the car
needs to "learn" my driving habits, but I now have 1600 miles and no change.
They have already hooked my car up to the computer, and they say it is
under factory specs. I'm going to ask them to hook up the other car that
feels correct, and also my again, to see if there is anything that might
show up. By the way, I love this car and there is no wind noise!! I'm just
hoping that there is a solution for this "lag" issue.
Old 09-06-08, 07:25 PM
Johnny
Johnny's Avatar
needs to "learn" my driving habits.
That's original... Where do they get these brush-offs?
Old 09-13-08, 12:17 PM
lexier
lexier's Avatar
I just got a call from the dealer, they said that they test drove two LS460's that were in for other service issues, and that they both had the same symptoms that mine has. (As if it is normal and get over it) I'm wondering if any of you have had the problem. I just can believe it is normal. When I drove one of the new cars, it did not seem to do it. I have ask them to check with Lexus on a possible solution. Anyone else have any answers?
Old 09-13-08, 01:21 PM
MythBuster
MythBuster's Avatar
Sorry I did not see your comments, but it has to be common sense. You are correct if I push it too hard (Some times I do) .
The L 10 life of bearings is a function of load and RPM. Higher speed will defnatly reduce the bearings life.
But I try to stay within 3500 rpm which should not be too bad.
Old 09-13-08, 01:31 PM
MythBuster
MythBuster's Avatar
When I get up to the speed of 40mph, I then lift my foot off the gas and it drops to 30mph in approx 10 - 12 seconds
I will test mine to see how long it will take to drop from 40 t0 30
but you did not tell us what is the rpm at 40, and the rpm at 30.
I would think the gear will be at the 4th or third change at 40 m/h
After my first post I start to look carfuly, I think it hapens in the early morning, but as the gear box oil heats up it does not do that any more. (I have to verify this though)
There must be away to reprogram the shifting points. You may ask the dealer if they can advance the shifting by 2% for example. (Just brain storming)
Old 09-13-08, 02:43 PM
Received 2,428 Likes on 1,591 Posts
Unless you guys plan to keep your cars for 200K mi. and beyond, you have nothing to worry about either way.
And brakes are cheaper than transmissions.
Old 09-15-08, 09:09 AM
lexier
lexier's Avatar
Thanks MythBuster for your suggestion on advancing the shifting by 2%. I'll ask them if there is such an adjustment. I checked the RPM's.
40MPH = 1300RPM's then as it drops to 30MPH the RPM's drop to 1000, then it shifts (and frees up to a normal coasting) at 1200 RPM's. There is also the same type of drag when I bring the speed upto 30MPH and coast down to 20MPH. 30MPH = 1000RPM's and drops to 20MPH at 800RPM's then shifts and frees up at 1000 RPM's
Quick Reply: Transmission "lag" when decelerating
