Anyone have 19" Touring wheels on *SWB* LS460?
As long as the rolling diameter of the tire is the same you will not have any problems. What that means is just measure the out side of the tires meaning the entire round tire tread part, you could just use a piece of string.
I have the 19's on my LWB but I have air suspension. I've seen 19's on LWB without air suspension but it was a different style 19. The 19's i have are what is pictured.
If your going that far with swapping out wheels I would also go for the larger brakes when they wear out. I have 6?4 piston calipers with ceramic pads....
If the rolling diameter is larger it may bottom requiring larger springs out or cause the speedo and other electronic things to be inaccurate.
I measured these two wheels and agree with those numbers. That 0.4" difference in diameter represents an increase in distance of 1.25” per turn at the wheel (0.4" x pi). At 60mph, the 19” wheel travels a further 4,752 feet, or a 1.5% increase, and an approximate rate of speed of 60.9 mph. In car design circles, that change would be considered negligible, and I strongly doubt they would re-calibrate the speedometer/odometer, considering that tire wear eventually throws this difference out the window anyway. The same thinking applies to wheels with larger diameter rims, as long as the tire's OD is close to factory specs.
