How to turn off Nav Breadcrumbs - 08 LS460
Hi, I was mucking around with the Nav and added a few memory locations (funny, no icon for airport, just ship??). Possibly, as a result, I now have little breadcrumbs over all streets, HW, etc. and this makes it hard to read the screen.
My major Q is how to turn these breadcrumbs off?
Thanks, WR
jeff
P.S. I'm also considering the Nav hardware switch override (ridiculous to pull over and have wife enter new locations), does anyone know if near-term, lexus will ever do a Nav SW upgrade (I have v7.1) that removes the in-motion restriction?
Thanks, WR
jeff
Shouldn't "POI off" voice command get rid of all icons? If you created a bunch of Memory Points that you don't want, you can go into the settings for Edit memory points and delete them.
Thanks, WR
jeff
Thanks, WR
jeff
you can get the override module from PS. send an email to kevin@prestigioussociety.com or chung@prestigioussociety.com, they are very helpful. i didn't follow that much on the prices though
that's what i thought as well. otherwise, i think when you are on the map, click on one of the icons at the bottom of the screen and there should be a screen to remove POI
Update: Actually, I can delete memory markers (icons 1-5), however the nav system is dropping small circular breadcrumbs on each new street/HW I take now.
Couldn't find any settings to turn this off even walking thru the supplied Lexus Nav training DVD.
I also turned off the POIs (reset to default) to no effect.
Undocumented feature I triggered?
jeff
jeff
Thanks, WR
jeff
Thanks, WR
jeff
go to map view hit stop record then cancell previous
