stock air suspension
hi, i am a newbie in search of a ls460, but how do i determine if it has a stcok air suspension on it? is there a certain button on the center console to look for or is there any other way to identify it? i currently have a ls430 and i know how to determine ls430's if they have air, but i have no idea how to determine if an ls460 has air suspension.
also did the ls460 come out with stock air suspension or is it only the ls460l?
can someone help me out. thanks.
That is correct, the pneumatic suspension is not available on the standard short wheel base LS460, only on the long wheelbase *and the short wheelbase AWD*. In addition, there is a "Height" button that actuates lifting or lowering the car three inches.
You know, I wonder if there is a way to use the Height High button to lower the car? I'm sure the dealer could set the limits of that switch so that in normal mode the car is lowered (more than normal) and with the height high switch pressed the car returns to a normal height?
exclusive matchup
yes, if you have the height control button, you have air suspension. otherwise, you don't have it
G2, the height control button doesn't really adjust the car much at all. i am sure you can adjust or play with the leveling rod to make use of that button, but i won't expect night and day difference. if you want to be able to really lower your car, the ride controller is the only option
do you know if they have different types of leveling rods like for the ls430,they have a company by the name of you zealand that sells a type of drop block that goes on the end of the strut that would drop the car an additional inch or 30mm.
sorry for all the dumb questions, but i want to research the car before i buy one. if you give me an ls430, i can tell you a lot about it, but the ls460 i'm lost... thanks again for your help..
exclusive matchup
if you get it from prestigious, they include all installation instructions anyway
