LED turn signal mirror hookup?
Just installed the LED covers using DIY on the IS forum (very similar install) but the wiring is not the same. Does anyone know which wires on the LS to tap into so I don't have to go all the way back to the tail lights?
Thanks
Back turn signals are the way to go and then chase the wires up the right side of the car. Chase left side wires over to the right side under the dash (as per the IS instructions) and hook up all the wires under sill plate. That's the way I did it but unfortunately I didn't take pictures. I got frustrated that I couldn't figure out which wires under sill plate to connect to. Could be because car is basically digital??? Just tap directly into tail light signal bulb wires. Good luck!
It appears that I am out of luck anyway as there was a change to the mirrors in 2008 and Nigel does not have the mirror for the 08-09 LS- DANGIT!! Guess I ll have to wait for the 2010.
Tom57
02-24-14 06:39 PM
kasper612
12-09-11 06:50 PM
