Noble Spinal paint anywhere?
Got a bit of a garf on my '08 LS rear bumper area. I'd like to find a can of shake 'n shoot for a temporary makeup job. Duplicolor's website just runs you around turnstiles.
Anybody found a good matching paint in aerosol can? I have the Lexu$ touch-up bottle, but this job would be better with touch up spray.
TIA
Whit
TIA
Whit
Paint wholesalers can mix an aerosol can to match any color. And, the nozzles are much better than the Duplicolor variety. I used this method years ago, so I'm sure there must be some that do this in your neck of the woods. It will cost more, but the results will be of much higher quality. You'll also have to follow up with some clear as well, as Lexus applies two coats at the factory, followed by a blending polish. There are also a few automotive paint websites that provide this service...
If this is too challenging, there are some mobile painters that can match both color & finish with surprisingly good results. Get references though...
Good Luck!
Good Luck!
