Sport vs Comfort and Height
Can someone tell me what the SPORT versus COMFORT mode is? My 2007 doesn't have that. Also there is a height button also on the center console. What is THAT?
Sport versus comfort is only available with the air suspension package. That is the setting choices of the air suspension. I'm pretty certain that only the "L" long wheel base versions offered the air suspension packages.
pretty self explanatory. Sport changes the suspension so that it 'should' handle better in the corners. less sway from the car, but should produce a harsher ride. Comfort is the opposite.
Height is to raise the car an inch or two so that your undercarriage doesnt hit anything, like a large speed bump
As a L owner I can add some personal experience. There is actually normal, sport and comfort. Personally I have it on the sport setting as is acts more like my previous 430 with sports suspension. Sport is stiffer and you feel small bumps more than with the normal setting, on the other hand it leans less in curves. Normal is probably like a regular 460 without the air suspension.
Comfort should have been called "boat" it really feels like an old fashioned '70 American barge floating across the road.
Most of the time I keep mine on the Comfort setting - keeps the wife happy. I'll use Sport when I anticipate cornering at higher than "normal" speed, or spirited driving maneuvers - the Power setting. The response is instantaneous.
No longer true since they started offering the AWD for the LS. Air suspension is standard for all AWD models, "L" or not.
That doesn't sound right. First of all, the change in height must be checked on a level surface - laterally and front to rear. Because the system is auto-leveling, your car may not necessarily be in the lowest position when you take your measurement. Also, an unsymmetrical load in the car will cause the modulator to adjust the air bags to suit that condition. Check it again, and if all the above are met, then you should have a chat with your dealer. There have been some reported problems here with this system, although they had to do with a lateral system lock-up.
