DIY / Info thread for LS460/LS460L/LS600hL
Old 05-29-16, 01:41 PM
  #61
Dr. Jekyll
Dr. Jekyll's Avatar
Coincidentally I just replaced my factory OSRAM Xenarc 66440 HID headlight bulbs with OSRAM Xenarc 66440CBIs. The difference is very subtle but side by side you can see the new CBIs are pure white. Very surprised to see Lexus using such high quality bulbs as OEM, only made sense for me to improve upon them even if it's a marginal improvement. All in all the upgrade took a flat head screwdriver, 10mm deep socket and 2 hours which includes removing both front wheels with the factory jack and a jack stand.
Dr. Jekyll is offline
Old 08-08-16, 09:04 PM
  #62
alexsea
alexsea's Avatar
Originally Posted by SW15LS
You only replaced one bulb and went to a different color temperature? Why not replace both?
I did replace both bulbs, just didn't post pictures :-)
Now, after a couple of months the right bulb is switching off after about ~30 min of driving :-(. Switching the lights off/on restores the light.
Is it a bad bulb or something else?
alexsea is offline
Old 08-09-16, 02:04 AM
  #63
1Putt
1Putt's Avatar
Most likely a bad bulb. Start with changing that
1Putt is offline
Old 01-01-17, 05:17 AM
  #64
mckellyb
mckellyb's Avatar
I know this is an old thread, but the right bulb turning on and off is a problem I had with a prior vehicle.
All it took to fix it was to clean the electrical contacts. I used Deoxit, because I have some, but there are other ways to accomplish the same thing.
edit: Dirty contact isn't an issue on this style of connector. I had one bad bulb and one which was close to bad.
mckellyb is offline
Old 06-21-17, 10:01 PM
  #65
PeteGS300
PeteGS300's Avatar
Deleted / Moved to the correct thread.
PeteGS300 is offline
Old 06-24-17, 10:38 AM
  #66
DavidinCT
DavidinCT's Avatar
Never saw this thread... Dam, lots if epic information that I never saw in the main DIY sticky, Thanks all ! Some things I will need to tackle
DavidinCT is offline
Old 07-01-17, 07:09 AM
  #67
lexus600hl
lexus600hl's Avatar
Default How do I remove the plastic cover of the seat bealt at left lower corner of seat?
Regarding 2008 ls 600 hl.
I am trying to clean the seat belts.
I would like to remove the small plastic cover, which is located at the bottom corner of the front passenger seat.
Imagine the seat side view as an "L:. The one end of the seatbelt is anchored at the corner of this L.
There is a plastic cover, covering this anchor.
How do I remove this plastic cover? It does not seem to pop out easily.
Thanks
lexus600hl is offline
Old 07-01-17, 07:26 AM
  #68
Received 2,730 Likes on 1,956 Posts
How heavy is the cleaning you're trying to do?
If the belts will need to be real wet I'd replace them. Most manufacturers recommend against cleaning them because it weakens the webbing.
SW17LS is offline
Old 07-01-17, 08:12 AM
  #69
DavidinCT
DavidinCT's Avatar
Heres a DIY question. Can one "add" OEM dynamic cruse to a LS460L ? With Park assist and being self parking, it has a crazy about of outside sensors. Besides what is behind the grill, what else would there be as for hardware ?
I know behind the front grill needs a LEXUS LS460 SENSOR ASSY, MILLIMETER WAVE RADAR GENUINE part number #88210-50100 then it needs the lexus logo that is a slimmer one so the radar could go through it.
And a button to enable it.... what else is needed ?
Old 07-01-17, 08:56 AM
  #70
lexus600hl
lexus600hl's Avatar
I just want to know how to remove the plastic cover. I don't want to side track the question. Thank you.
Old 07-01-17, 09:01 AM
  #71
It's your life lol
SW17LS is offline
Old 07-01-17, 10:13 AM
  #72
caha14
caha14's Avatar
Interesting question... One other thing to consider: radar cruise comes with PCS as well, and PCS adds another twist: the headlight assemblies are different as some sensors live there. What they do, I don't know, and I guess you could divorce PCS from radar cruise (provided those sensors in the headlights are only for PCS).
caha14 is offline
DavidinCT (07-01-17)
Old 07-01-17, 02:56 PM
  #73
DavidinCT
DavidinCT's Avatar
Thanks, that is what I was thinking. I see the front grill sensor is like $600+ used. I am sure I could talk someone down but, dont want to dump $500+ on something if it wont work.
Anyone else have any thoughts here ? (or should I create a new thread on this?)
Old 07-01-17, 05:13 PM
  #74
Anything is possible, but its going to be really expensive.
SW17LS is offline
Old 07-04-17, 10:00 AM
  #75
lexus600hl
lexus600hl's Avatar
Thanks
It pops UP. You can clean safely with Alcohol.
Quick Reply: DIY / Info thread for LS460/LS460L/LS600hL
