Anyone know where to get [used] LS 600 Headlights
1 Post
Hello guys,
has anyone seen a crashed LS 600 somewhere close to their area.
Im looking for used LS 600 Heads + Harness.
Brand New Heads are Expensive and not worth the price.
1 Post
Thanx man,
I found used LS 600 heads for 3000 USD but they dont come with the harness . I dont want to take the risk of buying the item. I still need the harness :-(
1 Post
The harness is an internal wire configuration applied to the LS 600 heads to allow them work on the LS 460 , but damn $4000 difference for modding the LS 600 heads to get them work on an LS 460 !!!!!!!!!!!!!
+ Shipping Cost ofcourse
Originally Posted by Seller I Found with Used LS 600 Heads
Hi, there.
We just re-searched the headlights for LS600h models and found the one set of the used headlights ASSY(they had been used just for 1 month/comes with the computer, bulbs and the other things to install to the LS600h).
Used headlights...$3230.00USD
Originally Posted by Seller I Found With Used LS 600 Heads + Harness
The LS600h Headlights conversion kit for LS460 without Pre-Crush System(Plug and Play/including LS600h headlights and conversion harness) is $7295.00USD. We cannot get the conversion harnes separately because the harness is already install the headlights assy. Unfortunately, the kit in used conditions is not available, and it is going to be really hard to get the used ones.
Lexus Connoisseur
1 Post
Thats what im thinking as well but problem is i have to search for an electrician that can do the job & then check wheather the heads will work or not.. I need the LED module that powers up the lamp and then have to adapt the wiring to power that module up , im not sure what else i might need.Here's is the part that i hate most , 25 mins to remove the bumper and another 40 mins to put it back on. Might Work or Might Not Work, depends on the wiring.
1 Post
Thanx ,
Thats a hell of a website i found the LS 600 heads for 2500 USD thats a hot price...
but still i need the harness.
I dont get the difference between
(with HID), L., w/LED low beams ( With led beams )
(with HID), L., w/o LED low beams ( Without led beams ) so theyre hids or what ?
ow & BTW my car is a left drive..
Damn that website is one of the best:
Your request has been submitted to many recyclers who may or may not reply to your request. The request remains in our system for 48 hours, if you do not receive a reply, you may resubmit your request, search in a wider geographical area, or assume that no one has that part.
