Wiring for Radar Detector
Hello Everyone: I was trying to find a hot wire for direct wiring of my radar detector. I tried many of the fuses on the drivers fuse box with no luck. I would wire it direct to the cigarette lighter but I do not know how to get to the cigarette lighter wiring. Is there another place to tie into or can someone tell me step by step how to get to the back of the cigarette lighter wiring? I am trying to find a hot wire that only works when the ignition is on and goes off when the ignition is turned off.
Thanks
Davedan - check is in the mail
jarm
Thanks
jarm
Thanks
jarm
Thanks
jarm
It is switched with the ignition and works perfectly.
Look in the manual at the fuse block diagrams and you should find it.
The fuse for the cigarette lighters (one in the ashtray, two on the rear of the center console) are located in the fuse panel under the dash on the passenger side. The fuse for the aux power socket inside the center console is located in the fuse panel under the dash on the driver side.
I'm trying hard to pull the trigger on a Passport 9500ci or the new Passport Qi45 installed systems. My installer said they replace the ashtray with a custom piece that houses the controller so it's hidden behind the ashtray cover panel. The alarm speaker goes under the dash out of sight.
^ Yeah, I must have used the AUX fuse location. It's been two years, so I've forgotten exactly which one. It IS the one under the dash on the driver's side, though.
As for the kind of detector, I'm running a Passport 8500 X50.
I think I will put this at the bottom of the priority list.
Anybody ever had any experience with the V1?
Yeah I was looking at the thread with the guy who has the GS350 who had it embedded in his rearview mirror, but then you still need to put the main unit where it can pick up the signals.
for me i put the radar right underneath the mirror. but again, that's only when i use the radar.
i have v1 and i will only use v1, quite a few of my friends had v1 and others and they all ended up with v1. it's great unit, i love it. paid what, 400 bucks? the amount it has saved me from the cops and chp and insurance is way way more
i think it's always been 399?
but anyway, hiding the wire isn't a big concern. on my gs400 and is300, i did the whole hardwire in less than an hour, just need to find the power wire inside the mirror (ignition hot) and you can easily do the wire around/behind teh mirror
https://store.valentine1.com/store/
I'm a big fan of the Valentine V-1, I have one in my pickup which I move to the LS on trips (wifey doesn't like the audio and she drives this more than I do.)
Seems like I tied it to a switched 12V source in the left footwell wire. I suspect there is another switched 12V source in the overhead console for a really short wire run to a windhield mount.
I also have one on the bike, stealth-mounted below the headlight, I ride in VA at times where they don't like you to use electronics to avoid them, but it's prefectly OK for them to use electronics to increase their revenue.
Valentine has remote audio and visual modules. I have those modules enclosed in a hard glasses case between the handelbars. If any VA or DC LEO's come swaggering over I just close the case...out of sight.
I've seen others do a similar remote mount on their cars in VA and DC by mounting the V-1 behind the grill and remoting the modules to the ashtray.
Whit
"This election was for you Mary Jo" - Rush 1/20/10
Whit
