Removing dome light cover - HELP
That's the most difficult cover to remove in these car imo, I switched all the non led bulbs in my 13 using a very thin flat blade jewellers screwdriver because the plastic ones were too thick and still made some marks. You can't see the marks unless you're looking for them, the 2 screws under the cover have to come off to drop the housing.
swfla (06-24-23)
Got the dome removed y'day to tap wiring. Gently pry on the bottom and you gotta remove two screws, inside the sunglasses holder.
