Upgrading the latest Gen 9.1 software on 2008 LS460
I have a 2008 LS460. Do anyone know if it is possible to upgrade the software to the one that is on 2010 LS460. I am not interested in upgrading the navigation data update, but the actual s/w that runs on the new models.
Cheers,
Sunil
Cheers,
Sunil
in my Chrysler some each time i updated the nav DVD there was slight program version changes too. not just data... i'm not sure the difference from the 08 and the 2010. if it is night and day i would agree with Rominl...
exclusive matchup
JFNash, would be good if that's the case for 2010, though i am still on the doubtful side. between gen2 to gen3 nav (say between the 02-03 GS), there was no way for you to update unless you get a whole new nav ecu. same with the gen4 to gen5 (between 06 and 07 GS), no way to upgrade unless you change the hardware.
Lexus Connoisseur
Your Gen 5 Nav interface is not interchangeable with the Gen 6 Nav in the 2010 models. You could upgrade to the Gen 6 Nav, but it will cost you rougly $12k in just hardware alone. The wiring harnesses between the two systems are not interchangeable as well. The cost of hardware, wiring and labor...it will not be worth the trouble. You would be better off trading up to a 2010.
Can anyone explain what the major differences are between the Gen 6 and Gen 5 NAV systems?
I just upgraded to the latest 9.1 map release and have noticed a few improvements, including losing the "I agree" screen and slightly different behavior while on a freeway. I assume that I'm still on Gen 5 version of the software.....
HBH
HBH
exclusive matchup
HBH
HBH
and yes, your car is still gen5
