Hit a pothole today and abs off light was flashing
Old 02-25-10, 04:25 PM
gs4mock2
gs4mock2's Avatar
Default Hit a pothole today and abs off light was flashing
WHILE I WAS DRIVING I HIT A NICE SIZE POtHOLE ,THE ABS OFF LIGHT WAS FLASHING AND THE VCS OFF LIGHT CAME ON ,FOR A WHILE ...THEN IT WENT OFF..........I WAS WONDERING WHAT WAS THE CAUSE .....
Old 02-25-10, 06:58 PM
Nospinzone
Nospinzone's Avatar
A pothole? In Brooklyn? Get out!
Most likely you jarred a sensor on the wheel. You should have it checked next time you're in for service.
And don't SHOUT.
Old 02-25-10, 07:04 PM
eternal07
eternal07's Avatar
shouldn't go over deep pot holes....
even bmw7 does show those lights when you go over deep holes....
of course, if you were driving prius, it will do that too...some prius says the car has brake failure problem, but nope it is not.
you are lucky that it didnt damage your rims
Old 02-26-10, 06:09 AM
Audriuss
Audriuss's Avatar
are u sure it wasn't just a TRC light that was flashing? Because LS brake system is by-wire and u no longer feel ABS working (wheels skiding) on brake pedal. It only starts to flash TRC light on the panel to let you know that ABS is working at the moment...so if you were touching brake pedal while hitting that pathole, it would explain everything...
Old 02-26-10, 08:05 AM
gs4mock2
gs4mock2's Avatar
the trc light was also on........huh if it happen again will pay more attention....thanks
Old 02-28-10, 03:55 AM
Audriuss
Audriuss's Avatar
If u some water on the road, try braking on that water to make wheels skid, and ABS working, and just watch lights on your panel..or go to some bigger speed and slam brake pedal as hard as you can...
CCChase
Suspension and Brakes
04-14-12 06:43 PM
hard2001
08-08-10 06:13 PM
samarooai1
02-14-10 02:22 PM
flipinsayi
GS - 1st Gen (1993-1997)
10-05-09 08:40 PM
Quick Reply: Hit a pothole today and abs off light was flashing
