Best Tire for LS460
#181
I would recommend the Continental ProContact LS tires. They are very smooth and quiet and absorb bumps really well.
Also, I almost forgot, another way to help reduce road noise up front that I tried, is using multiple rubberized sheets on the front plastic wheel wells.
I used the brand NOICO or one of the other brands you can buy on Amazon.
It has a black facing so it matches the underside and you can’t tell it’s there. I felt like it helped reduce tire noise after I installed like 3 layers of the sheets. But now since I have even quieter tires on my 460, the car is even more silent at highway speeds than ever before.
Honestly what helps reduce road noise or any kind of noise from the outside world, is having a heavy vehicle that has a lot of rubber components that it sits on. The more mass and materials used to insulate a cabin, the quieter it is and smoother riding because the added weight is able to absorb vibrations and road shock better as well.
This is why all the old school luxury land yachts of past road so smoothly and sublimely without fuss, because they all mostly weighed over 5,000lbs in curb weight with soft springs. Having an extra long wheelbase makes a huge difference in riding smoothness as well.
#182
Also very good tires...
And yes, that will help with road noise. I notice the 460 does not have carpeted wheel well liners in the front like my S560 does.
#183
#184
I would be much more comfortable with the thick quilted wheel well liners found today in various luxury vehicles.
Have to mention that it's funny the Mercedes EQS does not have those liners, and also has frameless windows and is somehow very quiet for road and wind noise.
Maybe we should start a new thread for road noise reduction? I have butyl at home, and would be more than happy to buy quilted liners if any are available in our size.
#185
Tried the Pilots, tried the Primacy, tried the std Goodrich. All wore very, very fast and all wandered. Pirelli Centurato P7 All Season Plus are outstanding. Smoother by far, quiet, hold a line and are refusing to show signs of wear. Until they become unavailable, I'll have nothing else on my LS460L AWD. If I thought a friend was installing something else, I would stage an intervention.
Dave144239 (04-24-23)
#186
I think I used an 80 mil thickness in this brand in black color, but I’m not sure they sell it in that size thickness anymore in black. It’s called Siless. Currently they sell the 50 mil sheets in black which is still fine, you might have to to use 3 layers to really help cut down on noise penetration.
The sheets are heavy and will add some weight to the wheel well, I simply cleaned up the plastic wheel well covers with rubbing alcohol, and used one of those heavy duty rollers to apply the sheets onto the covers.
After severe rainstorms that we’ve gotten out here in CA, the material has held up extremely well and hasn’t peeled off or anything.
You could also play with different materials such as the sheets of the closed cell foam in black, that could help absorb more road noise over the butyl rubber sheets.
The process is very easy and you can’t tell it’s even there. I do think Lexus should have added the felt liner up front on these cars which never made sense to me. But honestly the close cell foam and additional rubber sheets should do a better job at absorbing road noise than cheap felt liners.
Noise penetrates through materials including its vibrations, and the more material you use to stop the traveling or slow down that noise with additional barriers such as thick rubber or foam, the less of a chance that noise makes it way into the cabin.
I only used the butyl rubber sheets but I think using a combination of the rubber and the Closed Cell foam would be the best combination at reducing tire noise hands down.
You can find the products on Amazon on links below.
swfla (04-25-23)
#187
Here’s another one that I think would be best of both worlds.
Its a hybrid 3-1 using Closed Cell foam, Mass Loaded Membrane (great sound deadening/absorbing material) and B-Mastic (butyl rubber).
You might only need 1 or 2 sheets of this stuff and will definitely make a world of difference. The only problem is that you will probably need to spray the outside layer with black paint to cover up the logo, vs just using the black butyl rubber and or foam without the logo present.
The following 2 users liked this post by FlexnLexus:
Dave144239 (04-29-23),
swfla (04-25-23)
#188
Just replaced the OE Turanza ER33, I guess the OE tire the previous owner had installed at the dealer. They were down to 4/32 and getting pretty dicey on roads with standing water, so I replaced them with Continental Extreme Contact DWS06 Plus. Shocked at how much the ride improved, like the sharp edges of bumps were rounded off, and quieter as well. And with plenty of rain recently, they have been great on wet roads. I don't drive this car very aggressively, but it does seem grippy on dry pavement, cornering and emergency braking. Only have 400 miles or so on them, but very satisfied overall.
SW17LS (04-28-23)
#189
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20230922_075506_95d48b31089e964d6c52862fafca12671a15b62f.jpg)
swfla (09-22-23)
#190
The P7 3 is the replacement for your tires. I would buy them with confidence.
seanl (09-22-23)
#191
My other option is the Continental ExtremeContact DWS 06 Plus, which appears to be a bit more performance oriented:
https://www.tirerack.com/tires/tires...+Sport+Package
The corresponding Pirelli seems to be the P Zero AS Plus 3:
https://www.tirerack.com/tires/tires...port%20Package
Thoughts?
Thanks again.
#192
On my 3rd set of the P7's. 2nd set on the LS 460L which are the II's and 1 set on my 2006 SC 430 which are the original P7's. The 1st set on the LS got around 40K out of them. This LS is so heavy you will never get the 70K out of them. I rotate my tires every 5K with oil change. Love them. Taking the LS on a 1100 mile road trip this weekend.
Dennis
Dennis
seanl (09-22-23)
#193
Thanks, I appreciate your reply. I have a month or so, but definitely am going to pull the trigger before our rainy season.
Thoughts?
Thanks again.
Thoughts?
Thanks again.
P7s aren’t available in my sizes on the S Class or I would have gotten them. I have the P Zeros.
#194
Yep, totally understand that they're a bit more aggressive than grand touring tires. My commute often includes a 14+ mile canyon segment to bypass the freeway, and it's got more curves than Marilyn Monroe. My aging P7s did just fine yesterday, but I thought perhaps I might go one step more sporting...
#195
