22 inch lexani wheels rub???
Hi I just bought some new lexani wheels but the rear wheels rub. I thoght 22's fit right. What should I do. The tire shop tried to shave the panel but still rubs when making turns . Any good ideas?
22s doesn't mean much. the widths and offsets that's the key. if you get too aggressive setup, you will run for sure (even 20s could).
i don't get it though, do you rub front or rear? if it's rear and you shave enough fenders to avoid rubbing, turning won't cause any rub (rear wheels don't turn).
take pictures and see how aggressive they are now. my fenders were all shaved to clear the wheels and i had no problem
A3OD
09-12-21 07:33 AM
