Anyone changed the engine air filter?
I haven't taken the covers off yet to look, but I notice the owner's manual doesn't give any hints on changing the engine air filter.
I used to do all this kind of stuff myself, but they've made everything harder than it used to be. And the dealer charges to do simple things like this are usually more than they should be.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Anyone done this, and have any tips?
EDIT: NEVER MIND.
The air filter elements are easily accessible under the silver-colored engine cover via simple snap-clasp latches.
The problem seems to be finding the filters (there are two - one on each side). The most-advertised one is a K&N "performance" one, but they'll set you back $50 or more apiece. And good luck finding them locally. Best bet is probably to order them online. Or give up and buy them from Lexus parts.
Turns out mine look pristine, even after 33,000 miles. I couldn't even get any debris to shake out of them by pounding them upside-down on concrete.
EDIT: NEVER MIND.
After learning the OEM prices ($55 each), I pulled mine out, inspected them, and blew some compressed air through them (backward) to clean and see if they were allowing a good passage of air through, and found them to be acceptable. They looked very clean initially. There was some minor accumulation of dirt in the ductwork entrance which I cleaned out. If you are not doing any significant driving on dirt roads, I would guess they could easily go for 50K miles. I'm sure Lexus would like them swapped every 25K, but they are probably considering the worst case scenario.
K&N makes a washable one for $35, and it's available on Ebay.
But, yes, I was looking at the correct side.
After learning the OEM prices ($55 each), I pulled mine out, inspected them, and blew some compressed air through them (backward) to clean and see if they were allowing a good passage of air through, and found them to be acceptable. They looked very clean initially. There was some minor accumulation of dirt in the ductwork entrance which I cleaned out. If your are not doing any significant driving on dirt roads, I would guess they could easily go for 50K miles. I'm sure Lexus would like them swapped every 25K, but they are probably considering the worst case scenario.
Thanks for the tip, though. And like you say, unless you drive in dusty conditions, I think those sucker would go 50k!
Here's an update - I found them here http://www.lexpartsworld.com/scripts...?idproduct=306 for $24 each before shipping, if anyone is interested.
The parts number (sku) is 17801 38010.
Rom - you are right and I was wrong.
I was in a hurry and misread the plumbing the first time ... the air comes in from the bottom and passes up through the filter before going into the engine.
I took both filters out this time and blew them out - blowing from the top down through the filter media. I can tell you, though, that with 33,500 miles on the clock, the filters were amazingly clean. I spread the pleats with my fingers and couldn't find anything visible. When I blew the filters out with compressed air, there was a tiny puff of fine dust and that was it.
I must live a clean life.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
http://www.parts.com/oemcatalog/inde...9&model=LS 460
Enter part number on the left: 17801-38010
$20.73 each (OEM Toyota parts, not after market)
